Turn your port-scarce USB-C notebook to a mobile workstation with this Dell USB-C to HDMI/ DisplayPort adapter that comes with power pass-through.
                Uncompromised productivityTurn your port-scarce USB-C notebook to a mobile workstation with this Dell USB-C to HDMI/ DisplayPort adapter that comes with power pass-through. Its USB-C pass-through allows you to charge your laptop up to 90W while connecting to an external 4K HDR display at 60Hz simultaneously without compromising on screen performance.
                Supports high-quality video outputIncorporate an extra screen into your workflow by connecting either to the HDMI or DisplayPort on the combo adapter. Plug in your 4K HDR source to your adapter and get the same lifelike, impressive visuals with high color contrasts on your 4K 60Hz HDR display.
                Compact, lightweight designSlim and sleek, this adapter fits easily in your pocket or your laptop bag. The compact dimensions also ensure easy portability, so you can tote it anywhere.
                Easy Plug and PlayGet to work faster with instant Plug and Play - now you can easily connect the USB-C combo adapter to your laptop without the need to install a driver.
                Reliable performanceA comprehensive testing regimen ensures the ports and the connectors work each time, even with daily use. Its coaxial cable enhances signal quality, keeping connectivity and reliability absolute.
                Seamless compatibilityTested and certified to work with Dell systems, this USB-C adapter adheres to USB-C industry standards and works flawlessly every time.
- Dell Adapter USB-C to HDMI/DP with Power Pass-Through - adapter - DisplayPort / HDMI / USB - 18 cm
- Cable
- Adapter - DisplayPort / HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 60 Hz
- Length
- 18 cm
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- HDMI - female , DisplayPort - female , 24 pin USB-C - female
- 4K support, power pass-through
- 1-year warranty
- Cable Type
- Adapter 4K support, power pass-through
- Interface Supported
- Length
- 18 cm
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS X, Microsoft Windows, Google Chrome OS
- Connectors
- 19 pin HDMI Type A - female , 20 pin DisplayPort - female , 24 pin USB-C - female
- Limited warranty - 1 year
