Dell DELL 27N PLUS 4K USB-C MONITOR
Quicklinx: JGNWWS00 Mfr#: DELL-S2725QC
43 In Stock
£289.68 ex VAT
£347.61 inc VAT
The Dell 27 Plus 4K USB-C Monitor S2725QC delivers clarity and vibrant colors with its 27-inch 4K display, providing a native resolution of 3840 x 2160. With a brightness of 350 cd/m² and a contrast ratio of 1500:1, visual content comes to life. The monitor features a response time of 4 ms, making it suitable for casual users and gamers seeking smooth motion.
Equipped with connectivity options, the S2725QC includes USB-C, HDMI, and a built-in USB 3.2 Gen 1 hub, ensuring integration with various devices. The monitor also supports AMD FreeSync Premium technology, reducing screen tearing and supporting a smooth gaming experience. With its ergonomic design that allows height adjustment, tilt, swivel, and pivot, this monitor can be customized to provide comfort during extended use.
Dell Plus S2725QC - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2186109
Energy Class
Class F
Adaptive-Sync Technology
USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 120 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1500:1
Response Time
4 ms (grey-to-grey extreme), 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB (CIE 1931)
Input Connectors
2xHDMI, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
61.154 cm x 20.04 cm x 51.863 cm
6.71 kg
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
272 kg carbon emissions (EU)
Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, HDCP 2.3, TUV Rheinland Eye Comfort Certification (4-star)
Bundled Services
3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Built-in Devices
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
1500:1
Colour Support
Colour Gamut
99% sRGB (CIE 1931)
Response Time
Vertical Refresh Rate
48 - 120 Hz
Horizontal Refresh Rate
27 - 270 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, ultra-thin bezel design, Low Blue Light technology, Dell ComfortView Plus, flicker-free panel
61.154 cm x 20.04 cm x 51.863 cm - with stand (highest position)
6.71 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI (HDCP 1.4, HDCP 2.3) , USB-C upstream/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 65W) , USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , USB-C 3.2 Gen 1 downstream (power up to 15W)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management system
I/O cover
1 x USB-C 3.2 Gen 2 cable - USB-C - 1 m
Security Slot Type
Kensington security slot
Input Voltage
25 kWh/1000h
Power Consumption HDR (On mode)
37 kWh/1000h
Power Consumption (Typical)
21 Watt
Power Consumption (Max)
180 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand (lowest position) - width: 61.154 cm - depth: 20.04 cm - height: 38.863 cm - weight: 6.71 kg , With stand (highest position) - width: 61.154 cm - depth: 20.04 cm - height: 51.863 cm - weight: 6.71 kg , Without stand - width: 61.154 cm - depth: 6 cm - height: 35.598 cm - weight: 4.85 kg
Shipping Weight
8.9 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
Carbon Footprint
Manufacturing (kg CO2e)
125.79
Logistics (kg CO2e)
16.7
Use (kg CO2e)
123.35
EOL (kg CO2e)
5.88
Total Carbon w/o Use Phase (kg CO2e)
148.65
Bundled Services
10 - 80% (non-condensing)
Brand: Dell
