Get a wide viewing angle while saving desk space. This 21.5-inch Full HD monitor has a compact stand, slim profile and eco-conscious design.
Technical Details
Brand Dell
Product Dimensions 51 x 17 x 38 cm; 2.6 kg
Batteries 1 Lithium Ion batteries required.
Item model number E2222H
Manufacturer Dell
Series Dell E2222H Monitor
Colour Black
Standing screen display size 21.45 Inches
Screen Resolution 1920x1080
Resolution 1920 x 1080
Processor Count 1
Number of HDMI Ports 1
Voltage ?240 Volts (AC)
Are Batteries Included No
Lithium Battery Energy Content 2 Kilowatt Hours
Lithium Battery Packaging Batteries packed with equipment
Number Of Lithium Ion Cells 5
Number of Lithium Metal Cells 5
Item Weight 2.6 kg
Elevate your everyday display
An affordable 21.5" monitor made for your daily workflow. Featuring an elegant design, Full HD resolution and Dell Display Manager. -
Maximize your workspace
A thin profile and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk. -
Enhanced views
The Full HD resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions. -
Versatile connections
Dell’s E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs. -
Adapts to your needs
Make your workspace your own with VESA-compatible mounts and stands. -
Productive at every level
Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged. -
The key to convenience
Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster. -
More ways to manage
Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup. -
Guaranteed green
Compliant with the latest Energy Star standards, the E Series monitors meet stringent energy efficiency requirements while in sleep, on and off modes. They're also TCO-certified. -
Energy reducing
Save energy with PowerNap, a feature that dims or puts the monitor to sleep when not in use. -
Clean disposal
Composting or recycling the packaging is easy since it's made with at least 25% of recycled cardboard.
- Dell E2222H - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/605294
- Energy Class
- Class D
- Power Consumption (On mode)
- 12.13 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.249 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 10 ms (grey-to-grey normal), 5 ms (grey-to-grey fast)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- 50.426 cm x 17.1 cm x 38.417 cm
- 3.04 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 485 kg carbon emissions
- RoHS, NFPA 99, BFR-reduced, PVC-reduced
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 22"
- Viewable Size
- 21.45"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.249 mm
- Pixel Per Inch
- 103
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Mercury free, Dell ComfortView, arsenic free, Low Blue Light technology
- 50.426 cm x 17.1 cm x 38.417 cm - with stand
- 3.04 kg
- VGA , DisplayPort 1.2
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x DisplayPort cable
- Input Voltage
- 12.13 W
- Power Consumption SDR (On mode)
- 12.1 kWh/1000h
- Power Consumption (Max)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 50.426 cm - depth: 17.1 cm - height: 38.417 cm - weight: 3.04 kg , Without stand - width: 50.426 cm - depth: 4.964 cm - height: 29.538 cm - weight: 2.26 kg
- Shipping Weight
- 4.14 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 115
- Manufacturing (kg CO2e)
- 320.16
- Logistics (kg CO2e)
- 34.5
- Use (kg CO2e)
- 129
- EOL (kg CO2e)
- 2.16
- Total Carbon w/o Use Phase (kg CO2e)
- 356
- PAIA Version
- 1.3.0, 2021
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Other bundles (4)
Dell Slim DW316 USB External DVD Drive | In Stock | £40.60 |
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £25.61 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £25.61 |
Dell Dell Speakerphone SP3022 | In Stock | £67.46 |
