Dell Dell 22 Monitor - E2222H - 54.48cm
Quicklinx: HHK6WS00 Mfr#: DELL-E2222H
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 5ms
Interfaces: VGA (HD-15), DisplayPort
£62.97 ex VAT
£75.56 inc VAT
Get a wide viewing angle while saving desk space. This 21.5-inch Full HD monitor has a compact stand, slim profile and eco-conscious design.
Technical Details Brand Dell
Product Dimensions 51 x 17 x 38 cm; 2.6 kg
Batteries 1 Lithium Ion batteries required.
Item model number E2222H
Manufacturer Dell
Series Dell E2222H Monitor
Colour Black
Standing screen display size 21.45 Inches
Screen Resolution 1920x1080
Resolution 1920 x 1080
Processor Count 1
Number of HDMI Ports 1
Voltage ?240 Volts (AC) Are Batteries Included No
Lithium Battery Energy Content 2 Kilowatt Hours
Lithium Battery Packaging Batteries packed with equipment
Number Of Lithium Ion Cells 5
Number of Lithium Metal Cells 5
Item Weight 2.6 kg
  • Elevate your everyday display
    An affordable 21.5" monitor made for your daily workflow. Featuring an elegant design, Full HD resolution and Dell Display Manager.
  • Maximize your workspace
    A thin profile and improved cable management create a smaller footprint, lending itself to a clean, uncluttered desk.
  • Enhanced views
    The Full HD resolution is ideal for everyday tasks, while ComfortView is ready for extended viewing periods. It reduces up to 60% of harmful blue light emissions.
  • Versatile connections
    Dell’s E Series monitors accommodate legacy and non-legacy systems with convenient connectivity options like VGA and DP ports. Your workspace will be completely customized to your needs.
  • Adapts to your needs
    Make your workspace your own with VESA-compatible mounts and stands.
  • Productive at every level
    Dell Display Manager's (DDM) Easy Arrange feature lets you quickly tile and view your applications side by side across one or more connected screens for multitasking efficiency. And with the improved DDM, you'll get even more preset layouts.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
  • The key to convenience
    Shortcut keys can save you even more time, letting you easily configure your display management settings so you can get to work faster.
  • More ways to manage
    Asset management reports allow IT managers to quickly capture and track monitor information as well as configure multiple monitors at once through a single setup.
  • Guaranteed green
    Compliant with the latest Energy Star standards, the E Series monitors meet stringent energy efficiency requirements while in sleep, on and off modes. They're also TCO-certified.
  • Energy reducing
    Save energy with PowerNap, a feature that dims or puts the monitor to sleep when not in use.
  • Clean disposal
    Composting or recycling the packaging is easy since it's made with at least 25% of recycled cardboard.
Dell E2222H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/605294
Energy Class
Class D
Power Consumption (On mode)
12.13 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
10 ms (grey-to-grey normal), 5 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
50.426 cm x 17.1 cm x 38.417 cm
3.04 kg
Environmental Standards
TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
485 kg carbon emissions
RoHS, NFPA 99, BFR-reduced, PVC-reduced
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class D
Diagonal Size
22"
Viewable Size
21.45"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.249 mm
Pixel Per Inch
103
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, Flicker Free technology, Mercury free, Dell ComfortView, arsenic free, Low Blue Light technology
50.426 cm x 17.1 cm x 38.417 cm - with stand
3.04 kg
VGA , DisplayPort 1.2
Mechanical
Tilt
Tilt Angle
-5/+21
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable
Input Voltage
12.13 W
12.1 kWh/1000h
Power Consumption (Max)
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dimensions & Weight Details
With stand - width: 50.426 cm - depth: 17.1 cm - height: 38.417 cm - weight: 3.04 kg , Without stand - width: 50.426 cm - depth: 4.964 cm - height: 29.538 cm - weight: 2.26 kg
Shipping Weight
4.14 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
115
Manufacturing (kg CO2e)
320.16
Logistics (kg CO2e)
34.5
Use (kg CO2e)
129
EOL (kg CO2e)
2.16
Total Carbon w/o Use Phase (kg CO2e)
356
PAIA Version
1.3.0, 2021
Bundled Services
10 - 80% (non-condensing)
Accessories (1)
HHK6 Dell Dual Monitor Stand - MDS19 In Stock £145.32
Other bundles (4)
HHK6 Dell Slim DW316 USB External DVD Drive In Stock £36.19
HHK6 Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £34.22
HHK6 Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US In Stock £34.22
HHK6 Dell Dell Speakerphone SP3022 In Stock £48.62
Diagonal Size: 22in
Response Time: 5ms
Interfaces: DisplayPort
Brand: Dell
