Maximize space and view your screen with fewer distractions with this 21.5" Full HD monitor featuring three-sided slim bezels and a compact stand base.
- Dell SE2222H - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/557072
- Energy Class
- Class E
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.249 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 12 ms (grey-to-grey typical), 8 ms (grey-to-grey fast)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% sRGB (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- 50.426 cm x 17.881 cm x 38.408 cm
- 2.67 kg
- Carbon Footprint
- 492 kg carbon emissions
- TUV, RoHS, BFR-free, HDCP 1.4, PVC-free
- 1-year warranty with Advanced Exchange Service
- Bundled Services
- 3 years Advanced Exchange Service and Limited Hardware Warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 22"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.249 mm
- Pixel Per Inch
- 103
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Flicker Free technology, Dell Easy Arrange, Dell ComfortView, arsenic free, Low Blue Light technology, 3-sided bezeless
- 50.426 cm x 17.881 cm x 38.408 cm - with stand
- 2.67 kg
- HDMI (HDCP 1.4) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Included Accessories
- VESA screw cover, stand base, stand riser
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 14.1 kWh/1000h
- Power Consumption (Max)
- 22 watt
- Power Consumption Stand by
- 0.3 watt
- 0.3 watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 50.426 cm - depth: 17.881 cm - height: 38.408 cm - weight: 2.67 kg , Without stand - width: 50.426 cm - depth: 4.921 cm - height: 29.538 cm - weight: 2.34 kg
- Shipping Weight
- 4.4 kg
Sustainability Information
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 129
- Manufacturing (kg CO2e)
- 319
- Logistics (kg CO2e)
- 19
- Use (kg CO2e)
- 152
- EOL (kg CO2e)
- 2
- Total Carbon w/o Use Phase (kg CO2e)
- 340
- PAIA Version
- 1.3.2
- Limited warranty - 1 year
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
