Efficient power delivery
With a power output of 90 W, this adapter ensures sufficient energy supply for a range of devices, allowing for efficient performance during use. -
Compact design
The external form factor of the power adapter makes it easy to transport and store, perfect for mobile professionals and daily commuters. -
Durable connection
Featuring a 1 m power cable, this adapter offers flexibility in placement while maintaining a strong and reliable connection. -
Universal compatibility
The 24 pin USB-C connector allows for wide-ranging compatibility with many devices, simplifying charging and power management.
 - Dell - USB-C power adapter - 90 Watt
 - USB-C power adapter - external
- Localisation
 - United Kingdom
- Input Voltage
 - AC
- Power Capacity
 - 90 Watt
- Output connectors
 - 1 x 24 pin USB-C 90 W
 - 6.6 cm x 2.2 cm x 13 cm
 - 1-year warranty
- Localisation
 - United Kingdom
- Input Voltage
 - AC
- Power Output Connectors Details
- Power Capacity
 - 90 Watt
- Cables Included
 - Power cable 1 m
 - Limited warranty - 1 year
 - 6.6 cm
 - 2.2 cm
 - 13 cm
