Dell Dell - DDR4 - module - 32 GB - SO-DIMM 260-pin - 3200 MHz /
Quicklinx: H6MPWS00 Mfr#: AB120716
£155.79 ex VAT
£186.94 inc VAT
Upgrading your computer systems with Dell memory is the perfect way to maximize system uptime and ensure unmatched compatibility, reliability, and performance.
Dell - DDR4 - module - 32 GB - SO-DIMM 260-pin - 3200 MHz / PC4-25600 - unbuffered
Memory module
32 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
3200 MHz (PC4-25600)
Dual rank, unbuffered
DELL AB120716, DELL SNPP6FH5C/32G
Pricing Type
Upgrade
32 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Module Configuration
4096 x 64
Chips Organization
X8
Pricing Type
Upgrade
Brand: Dell
