The Dell Dual Video USB 3.0 Docking Station connects your notebook to up to two monitors, internet, and various external devices through a single USB cable. The Dock helps increase productivity through high-speed connectivity and expanded peripherals for all compatible notebooks or ultrabooks.
Universal connectivity for a customized workstation
Enjoy the ease of universal connectivity with the Dell Dual Video USB 3.0 Docking Station. A single cable from your notebook to the Docking Station provides connection to two monitors, various external devices and the internet so you can instantly expand and customize your workspace. -
Enhance productivity
Connect your notebook to the Docking Station and up to two monitors then enjoy an expanded desktop, working in multiple applications at once and expanding your usable screen space to help increase your productivity, when you connect your notebook to the Docking Station and up to two monitors. High-speed connectivity will keep you moving quickly, whether you're working with remote files, answering emails or streaming online content. -
One Docking Station for everyone
The Dell Docking Station is compatible with a variety of notebooks, from legacy products to the latest Dell notebooks, so you and your coworkers can all use the Docking Station. View presentations or movies on multiple large displays (up to 2560 x 1600 resolution) from a shared space in the office or at your home. -
A reliable station for all your home or office needs
No longer will you be constrained by the available ports on your notebook. Expand your workspace with dual displays and stay connected to all the devices you need to help increase your productivity at the office or for better flexibility at home.
- Dell Dual Video USB 3.0 D1000 - docking station - USB - VGA, HDMI, DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- VGA, HDMI, DP
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V (50/60 Hz)
- 1-year warranty
- Designed For
- Latitude E5270, E5460, E5470, E5570, E7270, E7470
- Product Type
- Docking station
- Data Link Protocol
- Gigabit Ethernet
- 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x network - Ethernet 1000 - RJ-45 , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x headset / headphones / microphone - input / output - mini-phone stereo 3.5 mm , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x SuperSpeed USB cable - external - 61 cm
- Security lock slot (cable lock sold separately), LED indicator, USB PowerShare technology, dual display support
- Security Slot Type
- Kensington security slot
- FCC
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 1 year
- 40 °C
- Designed For
- Dell Latitude E5270, E5460, E5470, E5570, E7270, E7470
