Foster collaboration while maintaining control of your meeting with this 55" 4K large format monitor.
Stunning visuals, striking presentations
Experience exceptionally sharp text and images with 4K resolution on a large format monitor that is optimized for text. -
More ways to display
Conveniently select from predefined templates with the Easy Arrange feature on Dell Display Manager Software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off. -
Dynamic colors, crisp details
A wide 178°/178° viewing angle lets you and your team see fine details and vibrant colors from either side of the room. -
Stay on schedule
Keep your meetings on track with a wide range of ports that allow you to easily connect and transition between presenters. -
Simplify your control
Automatically wake-up and shutdown your monitor and other devices while connected to compatible HDMI CEC devices. -
Lock it down
Reduce display changes in high traffic environments with lock mode, a feature that allows IT to control menu and power options.
- Dell C5519Q 55" Class (54.6" viewable) LED-backlit LCD display - 4K - for conference
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - conference
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15), DisplayPort, USB
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- 72% Color Gamut (CIE 1931)
- USB
- 3 ports
- Included Accessories
- Remote control, wireless remote control, 3 x wire saddles
- Voltage
- AC 120/230 V (50/60 Hz)
- 120 Watt
- Power Consumption (On mode)
- 100 W
- Energy Consumption per Year
- 143 kWh
- Dimensions (WxDxH) - panel
- 124.1 cm x 6.48 cm x 72.15 cm
- 20.5 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Carbon Footprint
- 2070 kg carbon emissions
- 3 years Basic Hardware Service with Advanced Exchange
- Product Type
- 120 Watt
- 100 W
- 143 kWh
- Diagonal Class
- 55"
- Diagonal Size
- 54.6"
- Commercial Use
- Yes - conference
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- Dimensions
- Panel
- 124.1 cm
- 6.48 cm
- 72.15 cm
- 20.5 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- LED backlight
- Coating
- Anti-glare, 3H Hard, 2% haze
- Dynamic Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Connector Type
- 2 x HDMI , DisplayPort , VGA input , Audio line-in , Audio line-out , USB 3.0 upstream , 2 x USB 3.0 downstream , RS-232 , USB 3.0 with battery charging , LAN
- Wireless remote control, 3 x wire saddles
- Cables Included
- VGA cable - 3 m , HDMI cable - 3 m , SuperSpeed USB cable - 3 m , DisplayPort cable - 3 m
- RoHS
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 343
- Manufacturing (kg CO2e)
- 766.9
- Logistics (kg CO2e)
- 434
- Use (kg CO2e)
- 848
- EOL (kg CO2e)
- 24
- Total Carbon w/o Use Phase (kg CO2e)
- 1222
- PAIA Version
- 1.2.15, 2021
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- No
- Bundled Services
- Weight (Shipping)
- 27.57 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
