Empower your business to do more. The versatile Dell C3765dnf multifunction color laser printer offers value, quality and efficiency to medium and large workgroups.
Collaborate easily
Scan, share, search and organize documents securely using Nuance PaperPort Pro 14. -
Connect anywhere
Manage documents conveniently with PaperPort Anywhere cloud service. -
Save operating costs
Convert your documents to electronic data to help increase efficiency and reduce paper expenses. -
Get visible results in a flash
Blaze through heavy-duty print and copy jobs at up to 36 ppm letter(in both mono and color) with ColorbyDell and Innovative Image Enhancement Algorithm. -
Help ensure the safety of your data
Work confidently with password protection, LDAP protocol and Kerberos authentication. -
Take control
Enjoy an intuitive operating panel with 4.3-inch color LCD touch display and one-touch Energy Saver mode activation. -
Maximize your money
Take advantage of low cost per page, with a separate replaceable toner cartridge and drum life of up to 60,000 pages each Cyan, Magenta, Yellow and Black. -
Rely on high performance
Handle high print volumes easily with a maximum duty cycle of up to 80,000 prints per month. -
Expend less energy
Cut consumption with fast-fusing EA Eco-Toner technology and sleep mode at the touch of the Energy Saver button. The N-Up feature is designed to let you print multiple pages on a single sheet of paper. -
Catch costly waste before it can happen
Monitor, track and manage color usage with Color Track Pro v1.1.
- Dell C3765dnf - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 80000 impressions
- Recommended Monthly Volume
- 2400 pages
- Max Copying Speed
- Up to 35 ppm (mono) / up to 35 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Display
- 4.3"
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Print from USB flash drive, scan to application, scan to network
- 43.9 cm x 53 cm x 55.8 cm
- 32.6 kg
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 80000 impressions
- 2400 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB 512 MB
Copying
- Max Copying Speed
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PCL 6 (XL 2.1), XPS, PDF 1.6
- Colour Management Features
- Application-based colour management
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- 50 sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Speed Details
- Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 23 ppm - B/W duplex , Printing: up to 23 ppm - colour duplex , Printing: up to 36 ppm (Letter A) - B/W , Printing: up to 36 ppm (Letter A) - colour , Copying: up to 36 ppm (Letter A) - B/W , Copying: up to 36 ppm (Letter A) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- SNMP, HTTP
- Kerberos, LDAP, SSL, TLS, IPsec, AES-256
- Operating System Support
- Novell NetWare, MS Windows XP, UNIX, MS Windows Server 2003, IBM AIX 5.1, IBM AIX 5.2, MS Windows 7, SuSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Desktop 11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), HP-UX 11i v2, MS Windows Server 2008, IBM AIX 5.3, Red Hat Enterprise Linux 5 Desktop, MS Windows Server 2008 R2, Apple Mac OS X 10.3.9 - 10.7, Oracle Solaris 9, IBM AIX 6
- Software Included
- Drivers & Utilities, Dell Toner Management System, Dell Printer Configuration Web Tool, Dell Private MIB 0.85, Dell ColorTrack Professional 1.1
- Included Accessories
- Phone cable, fax terminator
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 3000 pages , 1 x toner cartridge (magenta) - up to 3000 pages , 1 x toner cartridge (yellow) - up to 3000 pages
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 43.9 cm
- 53 cm
- 55.8 cm
- 32.6 kg
