Stay in sync on a Full HD monitor with built-in conferencing essentials, low blue light and an eco-friendly design.
 - Dell 27 Video Conferencing Monitor C2723H - LED monitor - Full HD (1080p) - 27"
 - LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/1006737
- Energy Class
 - Class C
- Power Consumption (On mode)
 - 13.2 W
 - Microphone, camera, USB 3.2 Gen 1 hub
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.3114 mm
- Brightness
 - 300 cd/m²
- Contrast Ratio
 - 1000:1 / 1000:1 (dynamic)
- Response Time
 - 5 ms (fast), 8 ms (normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 99% sRGB
- Input Connectors
 - HDMI, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 100-240 V (50/60 Hz)
 - 60.99 cm x 19.01 cm x 53.415 cm
 - 7.24 kg
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
 - 620 kg carbon emissions
 - RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
- Bundled Services
 - 3 years Advanced Exchange Service
- Display Type
- Energy Class
 - Class C
- Diagonal Size
 - 27"
- Built-in Devices
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.3114 mm
- Pixel Per Inch
 - 81.59
- Brightness
 - 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 99% sRGB
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
- Backlight Technology
 - LED backlight
 - Mercury free, arsenic-free glass, Low Blue Light technology, 3-sided bezeless
 - 60.99 cm x 19.01 cm x 53.415 cm - with stand
 - 7.24 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 5 Watt
 - HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 2 x USB 3.2 Gen 1 downstream , Headphones (mini-jack)
Mechanical
- Tilt Angle
 - -5/+21
- Swivel Angle
 - 90
- Height Adjustment
 - 150 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
 - 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 13.2 W
- Power Consumption SDR (On mode)
 - 13.2 kWh/1000h
- Power Consumption (Max)
 - 85 Watt
- Power Consumption Stand by
 - 0.3 Watt
- Power Consumption Sleep
 - 0.3 Watt
 - 0.2 Watt
- On / Off Switch
- Dimensions & Weight Details
 - With stand - width: 60.99 cm - depth: 19.01 cm - height: 53.415 cm - weight: 7.24 kg , Without stand - weight: 5.04 kg
- Shipping Weight
 - 10.01 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
 - 130
- Manufacturing (kg CO2e)
 - 398.1
- Logistics (kg CO2e)
 - 89
- Use (kg CO2e)
 - 128
- EOL (kg CO2e)
 - 5.61
- Total Carbon w/o Use Phase (kg CO2e)
 - 492
- PAIA Version
 - 1.3.0, 2021
- Bundled Services
Accessories (1)
                        Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (2)
                        Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £10.03 |
                        Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £50.12 |
