Dell C2723H 27" 1920x1080 5ms HDMI DisplayPort IPS LED Video Conferencing Monitor
Quicklinx: HFWWWS00 Mfr#: DELL-C2723H
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£188.37 ex VAT
£226.04 inc VAT
Stay in sync on a Full HD monitor with built-in conferencing essentials, low blue light and an eco-friendly design.
Dell 27 Video Conferencing Monitor C2723H - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1006737
Energy Class
Class C
Power Consumption (On mode)
13.2 W
Microphone, camera, USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 1000:1 (dynamic)
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
60.99 cm x 19.01 cm x 53.415 cm
7.24 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
620 kg carbon emissions
RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
81.59
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Mercury free, arsenic-free glass, Low Blue Light technology, 3-sided bezeless
60.99 cm x 19.01 cm x 53.415 cm - with stand
7.24 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , DisplayPort output (MST) , USB 3.2 Gen 1 upstream , 2 x USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 2 x USB 3.2 Gen 1 downstream , Headphones (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB-A to USB-B cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
13.2 W
13.2 kWh/1000h
Power Consumption (Max)
85 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 60.99 cm - depth: 19.01 cm - height: 53.415 cm - weight: 7.24 kg , Without stand - weight: 5.04 kg
Shipping Weight
10.01 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
130
Manufacturing (kg CO2e)
398.1
Logistics (kg CO2e)
89
Use (kg CO2e)
128
EOL (kg CO2e)
5.61
Total Carbon w/o Use Phase (kg CO2e)
492
PAIA Version
1.3.0, 2021
Bundled Services
Accessories (1)
HFWW Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (3)
HFWW Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £10.03
HFWW Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £37.01
HFWW Dell Thunderbolt Dock WD22TB4 180W In Stock £170.53
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Brand: Dell
