Dell C2722DE 27" 2560x1440 6ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: GQQZWS00 Mfr#: DELL-C2722DE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, USB-C
£295.96 ex VAT
£355.15 inc VAT
Collaborate like you're there on a 27-inch QHD monitor with an integrated 5MP camera, dual 5W speakers and a dedicated Microsoft Teams button.
  • One button, tons of benefits
    Introducing the world's first 27-inch QHD video conferencing monitor certified for Microsoft Teams, purpose-built so you can launch the Teams application, join meetings and respond to notifications with a press of a button. Plus, there is an LED indicator to notify you about a Teams alert.
  • Collaborate like you're there
    With the high definition 5MP IR camera, dual 5W integrated speakers and noise-canceling mic, you can feel in-person even while you're remote.
  • Quick, safe protection
    Save time signing in with secure, Windows Hello facial recognition that's faster than remembering and typing your password.
  • Immersive collaboration
    Collaborate like you're there. Razor-sharp video clarity of the pop-up 5MP IR camera gives you more than twice the details and zoom of a 2MP on a wide, beautiful screen. Dual 5W integrated speakers deliver clear, vibrant communication from any workspace quashing background chatter with noise-canceling microphone.
  • Enhanced security
    The pop-up web camera hides safely out of sight when not in use, and there's an intelligent layer of security with facial recognition through Windows Hello.
  • Seamless video from all angles
    FHD video with 30 frames per second rate delivers seamless, media-quality video and stunning screen clarity. The 178°/178° wide viewing angle presents superior views and consistent colors ideal for video conferencing.
  • Connect to productivity
    With wired connectivity options like RJ45 and USB-C, your monitor delivers reliable Ethernet, power, audio and video - all in a clutter-free setup.
  • Crafted for eye wellness
    ComfortView Plus is an always-on, built-in low blue light screen that optimizes eye comfort by reducing potentially harmful blue light emissions while delivering excellent color accuracy.
  • Comfort is key
    Tilt, swivel, pivot and adjust the height of your monitor to a maximum of 120mm because you should be comfortable however and wherever you work.
  • Seamless transitions
    The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
Dell 27 Video Conferencing Monitor C2722DE - LED monitor - 27" - with 3-year Basic Advanced Exchange
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
22.8 W
5.0 megapixel camera, USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
61.234 cm x 23 cm x 44.557 cm
8.8 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
642 kg carbon emissions
RoHS, DisplayPort 1.2, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
Bundled Services
3 years Advanced Exchange Basic Warranty
Latitude 5320, 5520; Precision 7560; XPS 15 9510
Display Type
Energy Class
Class F
Diagonal Size
27"
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.79
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless, 99% sRGB colour gamut
61.234 cm x 23 cm x 44.557 cm - with stand
8.8 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 downstream (power up to 15W) , 2 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Headphones , Network (RJ-45) , DisplayPort output (MST)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management panel
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
22.8 W
22.8 kWh/1000h
Power Consumption (Typical)
26.5 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 61.234 cm - depth: 23 cm - height: 44.557 cm - weight: 8.8 kg , Without stand - width: 61.234 cm - depth: 5.393 cm - height: 42.543 cm - weight: 5.74 kg
Shipping Weight
9.21 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
108
Manufacturing (kg CO2e)
402
Logistics (kg CO2e)
68
Use (kg CO2e)
169
EOL (kg CO2e)
4
Total Carbon w/o Use Phase (kg CO2e)
473
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 15 9510
Accessories (1)
GQQZ Dell Dual Monitor Stand - MDS19 In Stock £166.08
Other bundles (4)
GQQZ Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £7.90
GQQZ Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £147.00
GQQZ Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £47.93
GQQZ Dell Thunderbolt Dock WD22TB4 180W In Stock £188.18
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: USB-C
Brand: Dell
