Collaborate like you're there on a 27-inch QHD monitor with an integrated 5MP camera, dual 5W speakers and a dedicated Microsoft Teams button.
One button, tons of benefits
Introducing the world's first 27-inch QHD video conferencing monitor certified for Microsoft Teams, purpose-built so you can launch the Teams application, join meetings and respond to notifications with a press of a button. Plus, there is an LED indicator to notify you about a Teams alert. -
With the high definition 5MP IR camera, dual 5W integrated speakers and noise-canceling mic, you can feel in-person even while you're remote. -
Quick, safe protection
Save time signing in with secure, Windows Hello facial recognition that's faster than remembering and typing your password. -
Immersive collaboration
Collaborate like you're there. Razor-sharp video clarity of the pop-up 5MP IR camera gives you more than twice the details and zoom of a 2MP on a wide, beautiful screen. Dual 5W integrated speakers deliver clear, vibrant communication from any workspace quashing background chatter with noise-canceling microphone. -
Enhanced security
The pop-up web camera hides safely out of sight when not in use, and there's an intelligent layer of security with facial recognition through Windows Hello. -
Seamless video from all angles
FHD video with 30 frames per second rate delivers seamless, media-quality video and stunning screen clarity. The 178°/178° wide viewing angle presents superior views and consistent colors ideal for video conferencing. -
Connect to productivity
With wired connectivity options like RJ45 and USB-C, your monitor delivers reliable Ethernet, power, audio and video - all in a clutter-free setup. -
Crafted for eye wellness
ComfortView Plus is an always-on, built-in low blue light screen that optimizes eye comfort by reducing potentially harmful blue light emissions while delivering excellent color accuracy. -
Comfort is key
Tilt, swivel, pivot and adjust the height of your monitor to a maximum of 120mm because you should be comfortable however and wherever you work. -
Seamless transitions
The auto-restore feature remembers where you left off, so applications will go back to where you left them, even after you've unplugged.
- Dell 27 Video Conferencing Monitor C2722DE - LED monitor - 27" - with 3-year Basic Advanced Exchange
- LED-backlit LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 22.8 W
- 5.0 megapixel camera, USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- 61.234 cm x 23 cm x 44.557 cm
- 8.8 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 642 kg carbon emissions
- RoHS, DisplayPort 1.2, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 15 9510
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 108.79
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless, 99% sRGB colour gamut
- 61.234 cm x 23 cm x 44.557 cm - with stand
- 8.8 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 downstream (power up to 15W) , 2 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Headphones , Network (RJ-45) , DisplayPort output (MST)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, cable management panel
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 22.8 W
- Power Consumption SDR (On mode)
- 22.8 kWh/1000h
- Power Consumption (Typical)
- 26.5 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 61.234 cm - depth: 23 cm - height: 44.557 cm - weight: 8.8 kg , Without stand - width: 61.234 cm - depth: 5.393 cm - height: 42.543 cm - weight: 5.74 kg
- Shipping Weight
- 9.21 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 108
- Manufacturing (kg CO2e)
- 402
- Logistics (kg CO2e)
- 68
- Use (kg CO2e)
- 169
- EOL (kg CO2e)
- 4
- Total Carbon w/o Use Phase (kg CO2e)
- 473
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 15 9510
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £127.52 |
Other bundles (3)
Dell MS116 Mouse Optical Wired USB Black For Lattitude | In Stock | £8.65 |
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £163.47 |
Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey | In Stock | £49.25 |
