Dell C2422HE 23.8" 1920x1080 6ms HDMI DisplayPort USB-C IPS LED Video Conferencing Monitor
Quicklinx: HCZPWS00 Mfr#: DELL-C2422HE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: Speaker(s)
Interfaces: HDMI, DisplayPort, USB-C
£253.36 ex VAT
£304.03 inc VAT
Collaborate like you’re there on a 24-inch FHD monitor with an integrated 5MP camera, dual 5W speakers and a dedicated Microsoft Teams button.
  • One button, tons of benefits
    Introducing the world's first 24-inch FHD video conferencing monitor certified for Microsoft Teams, purpose-built so you can launch the Teams application, join meetings and respond to notifications with a press of a button. Plus, there is an LED indicator to notify you about a Teams alert.
  • Collaborate like you're there
    With the high definition 5MP IR camera, dual 5W integrated speakers and noise-canceling mic, you can feel in-person even while you're remote.
  • Quick, safe protection
    Save time signing in with secure, Windows Hello facial recognition that's faster than remembering and typing your password.
  • Personalized convenience
    Say what you need and let Cortana do the rest with hands-free commands.
  • Jumpstart productivity
    Simply press the monitor power button and the power sync feature seamlessly starts your monitor and connected Dell PC, even when the laptop lid is closed. Compatible with select Dell PCs.
  • Immersive collaboration
    Collaborate like you're there. Razor-sharp video clarity of the pop-up 5MP IR camera gives you more than twice the details and zoom of a 2MP on a wide, beautiful screen. Dual 5W integrated speakers deliver clear, vibrant communication from any workspace quashing background chatter with noise-cancelling microphone.
  • Enhanced security
    The pop-up web camera hides safely out of sight when not in use, and there's an intelligent layer of security with facial recognition through Windows Hello.
  • Seamless video from all angles
    FHD video with 30 frames per second rate delivers seamless, media-quality video and stunning screen clarity. The 178°/178° wide viewing angle presents superior views and consistent colors ideal for video conferencing.
  • Connect to productivity
    With wired connectivity options like RJ45 and USB-C, your monitor delivers reliable Ethernet, power, audio and video - all in a clutter-free setup.
  • The power of USB-C
    Get up to 90W of power delivery via USB-C, and charge your laptop (even when the monitor is off) with the Always On Power Delivery feature. This single-cable solution also saves up to 72% of workspace setup time, reduces cable clutter and transmits power, data and audio - all at once.
  • Quick convenience
    Plug in whatever you need and keep it in reach with the two, super speed USB 5Gbps (USB 3.2 Gen1) quick-access ports. There's even space to charge your mobile phone (up to 15W power charging) with the USB-C quick-access port.
  • Enhanced manageability
    Managing your monitor is easy with MAC Address pass-through, PXE Boot, and Wake-on-LAN conveniently built in.
  • Multitask efficiently
    Connect two PC sources to the monitor - intelligent Auto KVM feature detects the second connected PC and seamlessly switches controls over. KVM (keyboard, video and mouse) allows you to control both PCs with a single keyboard and mouse. Plus, you can enhance efficiency by 21% by adding a second monitor via the daisy chain feature.
Dell 24 Video Conferencing Monitor C2422HE - LED monitor - Full HD (1080p) - 24" - with 3-year Basic Advanced Exchange
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/394427
Energy Class
Class D
Power Consumption (On mode)
14.2 W
Daisy Chaining
5.0 megapixel camera, USB 3.2 Gen 1/USB-C hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare 3H hardness
Voltage
AC 100-240 V (50/60 Hz)
53.864 cm x 18.5 cm x 40.408 cm
6.12 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
602 kg carbon emissions
RoHS, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.56
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Flicker Free technology, Mercury free, arsenic-free glass, 3-sided bezeless
53.864 cm x 18.5 cm x 40.408 cm - with stand
6.12 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
HDMI (HDCP 1.4) , DisplayPort 1.2 (HDCP 1.4) , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 90W) , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 downstream (power up to 15W) , 2 x USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Headphones , Network (RJ-45) , DisplayPort output (MST)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support, cable management panel
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB-C cable - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
14.2 W
14.2 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption (Max)
195 Watt
Power Consumption Stand by
0.2 Watt
Power Consumption (Off Mode)
0.2 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.864 cm - depth: 18.5 cm - height: 40.408 cm - weight: 6.12 kg , Without stand - width: 53.864 cm - depth: 5.124 cm - height: 38.315 cm - weight: 4.33 kg
Shipping Weight
8.82 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
129
Manufacturing (kg CO2e)
400.33
Logistics (kg CO2e)
45.6
Use (kg CO2e)
153
EOL (kg CO2e)
2.87
Total Carbon w/o Use Phase (kg CO2e)
449
PAIA Version
1.2.13, 2021
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
Accessories (1)
HCZP Dell Dual Monitor Stand - MDS19 In Stock £166.38
Other bundles (4)
HCZP Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £10.03
HCZP Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £144.84
HCZP Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £37.01
HCZP Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £135.24
Diagonal Size: 24in
Response Time: 6ms
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
