The QLogic 5719 QP 1 Gb PCIe Network Interface Card from Dell is responsible for connecting your desktop and server to your network. Its remote management support enables you to maximize management resources.
- Broadcom 5719 - network adapter - Gigabit Ethernet x 4
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Designed For
- PowerEdge R220, R320, R420, R420xr, R520, R620, R720, R720xd, R820, R920, T130, T320, T330, T420, T430, T620, T630, VRTX, VRTX M520, VRTX M620
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Connectivity Technology
- Wired
- 1 Gbps
- Designed For
- Dell PowerEdge R220, R320, R420, R420xr, R520, R620, R720, R720xd, R820, R920, T130, T320, T330, T420, T430, T620, T630, VRTX, VRTX M520, VRTX M620
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.73 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
