The QLogic 5719 QP 1 Gb PCIe Network Interface Card from Dell is responsible for connecting your desktop and server to your network. Its remote management support enables you to maximize management resources.
- Broadcom 5719 - network adapter - PCIe - Gigabit Ethernet x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- Designed For
- PowerEdge R220, R320, R420, R420xr, R520, R620, R720, R720xd, R820, R920, T320, T330, T420, T430, T620, VRTX, VRTX M520, VRTX M620; PowerVault DL2300, NX3200, NX3300
- Network adapter
- Form Factor
- Plug-in card
- PCI Express
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 4 x 1000Base-T - RJ-45
- Designed For
- Dell PowerEdge R220, R320, R420, R420xr, R520, R620, R720, R720xd, R820, R920, T320, T330, T420, T430, T620, VRTX, VRTX M520, VRTX M620 , Dell PowerVault DL2300, NX3200, NX3300
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
