The WM615 Wireless Travel Mouse from Dell is a stylish, high-precision wireless mouse with a long battery life. The wireless connection through Bluetooth 3.0 helps provide users with a clutter-free mouse solution that enables users to create workspaces while on the go. This mouse is designed for comfort to allow mobile users to work or play on their notebooks for long periods without the usual stress on the wrists or hands. This mouse is easy to set up through Bluetooth 3.0, allowing you to simply pair with your computer and get started right away.
A high-performance mouse that you can take anywhere
The Dell Bluetooth Mouse-WM615 combines high-performance with an innovative design which lets you transform from comfort to ultra-portability and increase your productivity in virtually any setting. -
The unique twisting design slips into your bag with ease
Easily shift from usage to portability by twisting the Dell Bluetooth Mouse from the open shape that comfortably fits your hand when you're working, to the folded slim mode that you can slide into your pocket. -
Precise and reliable performance
With a touch strip for precision scrolling, an infrared LED tracking sensor and smooth left and right click areas, the mouse puts accurate and reliable performance at your fingertips. Navigate quickly and work more productively with this high-performance and ultraportable mouse. -
Increased productivity for your on-the-go lifestyle
Twist the Dell Bluetooth Mouse into slim mode and take it with you to the office, your favorite coffee shop, home or on the road. Untwist the mouse and you'll be equipped to increase your work productivity wherever your on-the-go lifestyle takes you. -
Connect wirelessly with ease
Advanced Leading Bluetooth SMART technology allows you to quickly and easily pair the mouse with Bluetooth 4.0-enabled computers and get to work. -
Curved for your comfort
With your comfort in mind, the Dell WM615 mouse has a curved shape designed to fit well in the palm of your hand. The touch strip and left and right click areas are positioned within easy reach that makes them seamless to use.
- Dell WM615 - mouse - Bluetooth
- Mouse
- Connectivity Technology
- Wireless - Bluetooth
- Movement Detection Technology
- Infrared
- Buttons Qty
- 2
- Scrolling, twisting design
- Battery
- AAA type
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Designed For
- Inspiron 17R 57XX, 17R 7720, 37XX, 53XX, 73XX 2-in-1, 7591 2, 77XX 2-in-1; Latitude 3310 2-in-1, 5310 2-in-1, 53XX, 55XX, 72XX 2-in-1, 7400 2-in-1, 94XX, D630; OptiPlex 50XX, 5250, 90XX; Vostro 13 5310, 14 54XX, 15 55XX, 15 7510, 34XX, 35XX, 53XX, 54XX, 5515, 7500; XPS 13 93XX, 15 7590, 15 95XX
- Mouse
Input Device
- Wireless
- Interface
- Bluetooth
- Infrared
- Buttons Qty
- 2
- AAA type
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10
- Designed For
- Alienware 13 R3, 15 R3, 17 R2, 17 R4, Alpha R2, Area-51 R3, Area-51 R4, Aurora R5, Aurora R6 , Dell Chromebook 11 3180, 11 3189, 13 3380, 3120 , Dell Inspiron 11 3168, 11 3169, 11 3179, 13 5368 2-in-1, 13 5378 2-in-1, 13 5379 2-in-1, 13 7353, 13 7368 2-in-1, 13 7375 2-in-1, 13 7378 2-in-1, 14 3421, 14 7460, 15 3555, 15 3559, 15 3565, 15 3567, 15 5565, 15 5566, 15 5567, 15 5568 2-in-1, 15 5576 Gaming, 15 5577 Gaming, 15 5578 2-in-1, 15 5579 2-in-1, 15 7560, 15 7569 2-in-1, 15 7572, 15 7579 2-in-1, 15 Gaming 7566, 15 Gaming 7567, 15 Gaming 7577, 15 N5010, 15 N5030, 15 N5040, 15 N5050, 15R 5520, 15R N5110, 17 5765, 17 5767, 17 7773 2-in-1, 17 7778 2-in-1, 17 7779 2-in-1, 17R 5720, 17R 5721, 17R 7720, 20 3064, 24 3464, 24 5459 AIO, 27 7775, 3043, 3045, 3052, 3059, 3263, 3264 AIO, 3265, 3268, 3459, 3662, 3668, 3670, 3780, 5348, 5391, 5458, 5459, 5477, 5545, 5552, 5558, 5675, 5755, 7306 2-in-1, 7370, 7373 2-in-1, 7380, 7391 2-in-1, 7459, 7472, 7570, 7573 2-in-1, 7580, 7591 2 in 1, 7786 2-in-1, 7791 2-in-1, Mini 10 1010, Mini 10 1012, Mini 10v 1018 , Dell Latitude 13 3379 2-in-1, 3180, 3189, 3310 2-in-1, 3480, 3580, 5175 2-in-1, 5280, 5285 2-in-1, 5289 2-In-1, 5310, 5310 2-in-1, 5320, 5414 Rugged, 5480, 5520, 5580, 7200 2-in-1, 7210 2-in-1, 7212 Rugged Extreme Tablet, 7214 Rugged Extreme, 7280, 7285 2-in-1, 7380, 7389 2-in-1, 7390 2-in-1, 7400 2-in-1, 7414 Rugged Extreme, 7480, 9410, 9420, D630 ATG, D630 XFR , Dell OptiPlex 3046, 3050, 5050, 5055, 5250 All In One, 7050, 7450, 9010 All In One, 9020 All In One , Dell Precision 3520, 5520, 5720 AIO, 7520, 7720, T1650 , Dell Vostro 13 5310, 14 5410, 14 5468, 15 5510, 15 5568, 15 7510, 200s, 260s, 3459, 3491, 3501, 3591, 5301, 5391, 5415, 5490, 5515, 7500 , Dell XPS 12 9250, 13 9300, 13 9310, 13 9310 2-in-1, 13 9350, 13 9360, 13 9365 2-in-1, 13 9370, 13 9380, 15 7590, 15 9500, 15 9550, 15 9560, 15 9570, 15 9575 2-in-1, 27 7760, 8910, 8920, One 2710, One 2720 , Dell Wyse 3030 LT
