Dell Alienware AW2725QF 27" Class 4K UHD Monitor
Quicklinx: JF28WS00 Mfr#: GAME-AW2725QF
More than 50 In Stock
£324.81 ex VAT
£389.77 inc VAT
The Dell Alienware 27 4K Dual-Resolution Gaming Monitor offers a viewing experience with its 27-inch screen and a native resolution of 3840 x 2160 or 1920 x 1080. This display features a brightness of 600 cd/m2 and a contrast ratio of 1000:1, delivering vibrant colors and deep blacks. With technologies such as TFT active matrix and an anti-glare coating, visuals remain sharp and clear from multiple angles, suitable for both gaming and media consumption.
Equipped with Flicker-Free technology and multiple preset modes like FPS, RTS, and RPG, this monitor ensures a comfortable viewing experience during long gaming sessions. Customizable options such as picture in picture and picture by picture allow users to maximize productivity. The Alienware monitor also includes a USB 3.2 Gen 1 hub for easy connectivity, height adjustment, and an energy-efficient design, contributing to an immersive and environmentally friendly setup.
Alienware AW2725QF - LED monitor - 4K / Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2046406
Energy Class
Class G
Power Consumption (On mode)
26.1 W
Adaptive-Sync Technology
VESA Adaptive-Sync, NVIDIA G-SYNC Compatible
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K / Full HD (1080p) 3840 x 2160 / 1920 x 1080 at 165 Hz
Pixel Pitch
0.1554 mm
Brightness
600 cd/m²
Contrast Ratio
1000:1
HDR Capable
Dolby Vision / DisplayHDR 600
Response Time
0.5 ms (grey-to-grey min), 2 ms (grey-to-grey super fast), 3 ms (grey-to-grey fast), 1 ms (grey-to-grey observed) in extreme mode
Gaming
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 95% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
61.144 cm x 24.37 cm x 51.868 cm
7.15 kg
Plug and Play, RoHS, BFR-reduced, PVC-reduced
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
27"
Viewable Size
26.95"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
600 cd/m²
Contrast Ratio
1000:1
HDR Format
Dolby Vision
HDR Certification
DisplayHDR 600
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 360 Hz
Horizontal Refresh Rate
30 - 470 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge LED
Picture in picture, picture by picture, FPS Mode, Flicker Free technology, RTS Mode, Mercury free, arsenic-free glass, Sports Mode, Eye comfort mode, RPG Mode, 8-bit + A-FRC Colour Depth, Dell ComfortView Plus, Delta E=2 colour accuracy, console mode, 3 customisable game modes
61.144 cm x 24.37 cm x 51.868 cm - with stand (highest position)
7.15 kg
2 x HDMI , DisplayPort 1.4 , USB 3.2 Gen 1 downstream (BC 1.2) , 2 x USB 3.2 Gen 1 downstream (Type A) , USB 3.2 Gen 1 upstream (Type B) , USB-C 3.2 Gen 1 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
40
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
26.1 W
26.1 kWh/1000h
Power Consumption HDR (On mode)
68 kWh/1000h
Power Consumption (Typical)
26.1 Watt
Power Consumption (Max)
140 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Alienware Command Center
Dimensions & Weight Details
With stand (lowest position) - width: 61.144 cm - depth: 24.37 cm - height: 40.868 cm - weight: 7.15 kg , With stand (highest position) - width: 61.144 cm - depth: 24.37 cm - height: 51.868 cm - weight: 7.15 kg , Without stand - width: 61.144 cm - depth: 6.74 cm - height: 36.118 cm - weight: 4.75 kg
Shipping Weight
11.18 kg
Bundled Services
10 - 80% (non-condensing)
Brand: Dell
