Maximize your workspace with the Dell E-Port Plus Replicator. This E-Port Plus Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices. It also gives you ease of mobility wherein you need not unplug and re-plug multiple peripherals to access your printer or other devices.
- Dell E-Port II Advanced - port replicator
- Product Type
- Port replicator
- 28.8 cm x 17 cm x 5.37 cm
- 1.05 kg
- Localisation
- United Kingdom, Ireland
- Power
- Power adapter - external 130 Watt Power Provided
- Designed For
- Latitude 6430u, E5250, E5270, E5420, E5420m, E5430, E5440, E5450, E5470, E5520, E5520m, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6430, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
- Product Type
- Port replicator
- 28.8 cm
- 17 cm
- 5.37 cm
- 1.05 kg
- Localisation
- 1 x headphones - output - mini-phone 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type A , 2 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x serial - 9 pin D-Sub (DB-9) , 1 x parallel - 25 pin D-Sub (DB-25) , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 2 x display / video - DisplayPort - 20 pin DisplayPort
- Power Device
- Power Provided
- 130 Watt
- Designed For
- Dell Latitude 6430u, E5250, E5270, E5420, E5420 N-Series, E5420m, E5430, E5440, E5450, E5470, E5520, E5520 BRC 6, E5520 N-Series, E5520m, E5530, E5540, E5550, E5570, E6230, E6320, E6320 N-Series, E6330, E6420, E6420 ATG, E6420 N-Series, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6520 N-Series, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
