Dell Active Stylus for Dell Tablet
Quicklinx: B3HRWS00 Mfr#: 750-AAHC
The Dell Active Stylus is designed to work with Dell tablets giving you better interaction, more precision and improved productivity. Whether you are taking notes or sketching pictures, the stylus gives you a more natural and precise way to interact with your tablet. The pen has also been pre-calibrated, meaning it is ready to perform naturally with your tablet right out of the box.
  • A smart stylus for improved productivity
  • 1mm tip with pressure-sensing technology
    The Dell Active Stylus has a fine 1mm tip that lets you draw precise lines - without the jagged edges that some other styluses can create. The stylus also has pressure-sensing technology, allowing it to mimic a traditional pen by drawing a thicker or thinner line depending on the amount of pressure applied.
  • Built-in buttons provide easy access to functions
    The stylus has two built-in side buttons that give you easy access to functions, including erasing, highlighting, and clicking.
  • Palm rejection for natural, comfortable use
    An internal transmitter lets your tablet know when the stylus is in use, preventing accidental actions if your palm or wrist rests on your tablet while you write. This allows you to write on your tablet naturally, just as you would on a pad of paper.
  • Hover sensing for predictable landing spots
    When the stylus is held near your tablet, the tablet automatically detects it. Your tablet even predicts and shows landing points for the stylus tip, so you don't accidentally write in the wrong spot.
Dell Active Stylus - active stylus
Active stylus
AAAA type
Inspiron 13 7347, 13 7348; Latitude 13 7350; Venue 11 Pro (5130), 11 Pro (7130), 11 Pro (7139), 11 Pro (7140), 5830 Pro, 8 Pro
Active stylus
AAAA type
Dell Inspiron 13 7347, 13 7348 , Dell Latitude 13 7350 , Dell Venue 11 Pro (5130), 11 Pro (7130), 11 Pro (7139), 11 Pro (7140), 5830 Pro, 8 Pro
