Dell 4TB 7.2K RPM SATA 6Gbps 3.5in Hot-plug Hard Drive
Quicklinx: BGQ8WS00 Mfr#: 400-AEGK
Form Factor: 3.5"
Type: Hard drive
Interface Type: Serial ATA-600
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£188.66 ex VAT
£226.39 inc VAT
Increase the storage capacity of your Dellâ„¢ system with this 4 TB Hard Drive from Dell. It boasts a storage capacity of 4 TB, enabling users to store large amounts of data. This hard drive features a Serial ATA interface and it offers a maximum rotational speed of 7,200 RPM. This product has been tested and validated on Dell systems and is compatible with select Dell Systems. It is supported by Dell Technical Support when used with a Dell system.
Dell - hard drive - 4 TB - SATA 6Gb/s
Hard drive - hot-swap
4 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
4 TB
3.5"
SATA 6Gb/s
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5"
Form Factor: 3.5"
Type: Hard drive
Capacity: 4TB
Brand: Dell
Stock Status: In stock
