Connect like you're there with a 27-inch QHD IPS display built for effortless collaboration.
Powerful webcam
Take center stage with a 2K QHD webcam that packs a punch. The large Sony STARVIS sensor is 29.5% larger than the previous model, takes in substantial light to give you vibrant picture clarity and a vivid image. -
Look great in low light
Temporal (3D) and Spatial (2D) Noise Reduction automatically eliminates motion blur and grainy images in low light, while AI Auto Framing keeps you in the middle of the frame even as you move around. -
Loud and clear
Collaborate like you're there with built-in, dual echo cancellation mics and dual 5 W speakers, strategically positioned at the top of the monitor for an immersive audio experience. -
Interaction secured
The manual webcam shutter and convenient microphone mute button on this Zoom-certified monitor helps ensure that you're only communicating what you want to share, when you want to share it. -
Easier connections
Launch Teams meetings effortlessly with the quick access touch control on this certified for Microsoft Teams monitor. -
Easy on the eyes
Work without straining your eyes with the always-on, built-in ComfortView Plus, which reduces low blue light without compromising color. -
Comfort is key
Tilt, swivel, pivot and adjust the height of your monitor up to a maximum of 150 mm. -
Connect to productivity
With wired connectivity options like RJ-45 and USB-C, your monitor delivers reliable Ethernet, power, audio and video - all in a clutter-free setup. -
Quick convenience
Plug in whatever you need and keep it in reach with the two, super speed USB 5 Gbps (USB 3.2 Gen 1) quick-access ports. There's even space to charge your mobile phone (up to 15 W power charging) with the USB-C quick-access port. -
Enhanced manageability
Managing your monitor is easy with MAC Address pass-through, PXE Boot, and Wake-on-LAN conveniently built in. -
Multitask efficiently
Connect two PC sources to the monitor - an intelligent Auto KVM feature detects the second connected PC and seamlessly switches controls over. KVM (keyboard, video and mouse) allows you to control both PCs with a single keyboard and mouse. Plus, you can enhance efficiency?by adding a second monitor via the daisy chain feature.
- Dell 27 Video Conferencing Monitor P2724DEB - LED monitor - QHD - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1378993
- Energy Class
- Class F
- Power Consumption (On mode)
- 26 W
- 2 microphones, IR camera, proximity sensor, USB 3.2 Gen 1/USB-C hub, RGB camera, IR sensor, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Ethernet
- Built-in Webcam
- 4 Megapixel - 2560 x 1440 at 30 fps
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (lowest position)
- 61.178 cm x 23 cm x 44.079 cm
- 8.27 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified
- Carbon Footprint
- 604 kg carbon emissions
- Plug and Play, RoHS, NFPA 99, BFR-free, PVC-free
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 90 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Integrated cable management, Flicker Free technology, daisy chain compatible, Mercury free, OSD controller, arsenic-free glass, Dell Easy Arrange, 3-sided bezeless, Dell ComfortView Plus, Auto KVM Switch
- 61.178 cm x 23 cm x 44.079 cm - with stand (lowest position)
- 8.27 kg
Built-in Webcam
- Sensor Resolution
- 4 Megapixel
- Max Video Resolution
- Digital Zoom
- 4
- Privacy shutter, Auto Focus, 78° field of view, Windows Hello compatible
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- HDMI (HDCP 1.4) , DisplayPort 1.4 (HDCP 1.4) , USB-C 3.2 Gen 1/DisplayPort 1.4 Alt Mode (power up to 90W) , DisplayPort output (MST) , USB-B 3.2 Gen 1 upstream , USB 3.2 Gen 1 (BC 1.2) , 2 x USB 3.2 Gen 1 , LAN , Audio line-out (mini-jack) , USB-C 3.2 Gen 1 downstream (data only)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft stand lock slot, Dell Power Button Sync
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m , 1 x USB-C 3.2 Gen 2 cable - USB-C - 1 m
- Software Certification
- Zoom Certified, Certified for Microsoft Teams, Microsoft Cortana Certified
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26 W
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption (Typical)
- 20.6 Watt
- Power Consumption (Max)
- 210 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager, Dell Peripheral Manager
- OS Required
- Windows 10, Apple MacOS 12.3.1 or later, Windows 11 (version 21H2)
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.178 cm - depth: 23 cm - height: 44.079 cm - weight: 8.27 kg , With stand (highest position) - width: 61.178 cm - depth: 23 cm - height: 59.079 cm - weight: 8.27 kg , Without stand - width: 61.178 cm - depth: 5.961 cm - height: 41.582 cm - weight: 5.65 kg
- Shipping Weight
- 11.26 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 157
- Manufacturing (kg CO2e)
- 333.67
- Logistics (kg CO2e)
- 57.97
- Use (kg CO2e)
- 205.82
- EOL (kg CO2e)
- 6.89
- Total Carbon w/o Use Phase (kg CO2e)
- 398.18
- PAIA Version
- 1.3.2, 2022
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE | In Stock | £171.38 |
