The Dell P2417H brings a different level of productivity to the work place without sacrificing comfort and convenience.
Purposefully designed for comfort and convenience
Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle. -
A more seamless workflow
Slim borders create a smoother and less obstructed visual experience when working across multiple monitors. -
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference. -
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices. -
Enhanced viewing experience
Perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue. -
Complete clarity
Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high dynamic contrast ratio. -
Work comfortably with less stress
Dell's ComfortView feature helps reduces harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled. -
A more fluid workspace
With Dell Easy Arrange, you can easily tile and view your software applications side by side. -
Reliable and responsible
Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
- Dell P2417H - without stand - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 25 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 4000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Dimensions (WxDxH) - without stand
- 54.98 cm x 5.03 cm x 32.6 cm
- 3.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- RoHS
- Display Type
- Energy Class
- Class A+
- 25 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Ultra wide viewing angle, Premium Panel Guarantee, Dell Easy Arrange, Dell ComfortView
- 54.98 cm x 5.03 cm x 32.6 cm - without stand
- 3.33 kg
- HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), anti-theft protection
- RoHS
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 19 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- Without stand - width: 54.98 cm - depth: 5.03 cm - height: 32.6 cm - weight: 3.33 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (3)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £135.75 |
StarTech.com Dual Monitor Stand | In Stock | £80.12 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.15 |
Other bundles (3)
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £17.25 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.20 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £16.49 |
