Dell 24" IPS LED Monitor P2417H VGA HDMI DP Black UK
Quicklinx: CBN3WS00 Mfr#: P2417H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 6ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
More than 50 in stock
£119.89 ex VAT
£143.86 inc VAT
The Dell P2417H brings a different level of productivity to the work place without sacrificing comfort and convenience.
  • Purposefully designed for comfort and convenience
    Easily adjust your monitor to your desired angle, height, and position so you can enjoy great visuals across multiple monitors with no hassle.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
  • Enhanced viewing experience
    Perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue.
  • Complete clarity
    Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high dynamic contrast ratio.
  • Work comfortably with less stress
    Dell's ComfortView feature helps reduces harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled.
  • A more fluid workspace
    With Dell Easy Arrange, you can easily tile and view your software applications side by side.
  • Reliable and responsible
    Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
Dell P2417H - without stand - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
54.98 cm x 5.03 cm x 32.6 cm
3.33 kg
Environmental Standards
ENERGY STAR Qualified
RoHS, TCO Displays
Display Type
Energy Class
Class A+
25 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, ultra wide viewing angle, 82% (CIE 1976) colour gamut, Premium Panel Guarantee, Dell Easy Arrange, Dell ComfortView
54.98 cm x 5.03 cm x 32.6 cm - without stand
3.33 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), anti-theft protection
RoHS, TCO Displays
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
Without stand - width: 54.98 cm - depth: 5.03 cm - height: 32.6 cm - weight: 3.33 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell 24 Bundle deal on Dell 24" IPS LED Monitor P2417H VGA HDMI DP Black UK
£219.06
Accessories (4)
CBN3 StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
CBN3 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CBN3 StarTech.com Dual Monitor Stand In Stock £69.36
CBN3 StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (7)
CBN3 C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.55
CBN3 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.28
CBN3 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.40
CBN3 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
CBN3 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.66
CBN3 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.34
CBN3 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.35
Diagonal Size: 24in
Response Time: 6ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
