Dell 2350d A4 Mono Laser Printer
Quicklinx: 7L1SWS00 Mfr#: 210-34537
Reliability at the speed you need
Impress your clients and co-workers with professional-quality double-sided printouts from the DellTM 2350d Laser Printer. Enjoy razor-sharp images and text and fast printing speeds with this dependable printer that will work hard for your office.
Bring big business performance to your small office with the Dell 2350d Laser Printer, which delivers professional-quality prints at a low total cost of ownership.
  • Keep documents flowing with print speeds of up to 38 A4 sized pages per minute (actual print speed will vary with use
  • Get great-looking prints with a maximum print resolution of 1200x1200 dpi.
  • Reduce paper use by using the built-in automatic duplexer for easy 2-sided printing. You can also print multiple pages on one sheet of paper using custom print modes.
  • Enjoy the long-term value you can get from a 60,000 page monthly duty cycle.2
Built with your business in mind
You want your print outs fast, and you expect your printer to work when you need it- everytime without fail. The Dell 2350d is designed for durability, delivering what you need when you need it.
Contents in the Box:
Dell 2350d Ship-With Black Cartridge (2,000 page yield 4)
Paper tray extended cover
Power cord
Software & Instructions CD
Michael Dell Recycling Program Letter (US and EMEA SKU Only)
Blue Angel Tech Sheet (EMEA only)
Japan Service Contact Sheet (Deviation) (Japan SKU)
PIG
NOM techsheet (DAO SKU)
UAR Sheet
  • This printer means business
    Bring big business performance to your small office with the Dell 2350d Mono Laser Printer, which delivers professional-quality prints at a low total cost of ownership.
  • Built with your business in mind
    You want your printouts fast, and you expect your printer to work when you need it - every time, without fail. The Dell 2350d is designed for durability, delivering what you need when you need it.
Printer Type
Laser
Printer Dimensions
16.61 x 14.53 x 10.24"
Printer Weight
14.13kg
Max Print Speed (actual print speed will vary with use)
Up to 38 ppm A4
Print Resolution
600 x 600 dpi (printer default), maximum 1200 x 1200 dpi
Maximum Monthly Duty Cycle
60,000 pages
Paper Input
Standard Tray (sheets): 250-sheet covered drawer (75 gsm stock) and 50-sheet multipurpose tray
Maximum Paper Input Capacity
Maximum (sheets):850 sheets (250-sheet drawer + 50-sheet multipurpose tray + 1 x optional 550-sheet drawer)
Standard/Maximum Output Capacity
Standard (sheets): 150 sheets bin
Optional Paper Input Accessories
One optional 550-sheet drawer can be fitted (maximum capacity 850 sheets inclusive of multipurpose tray)
Toner cartridges
Standard Yield: approx 2,0004 pages at 5% coverage, High Yield: approx 6,0004 pages at 5% coverage
Duplex (Two-sided printing)
Automatic duplex unit included as standard.
400 MHz
32 MB standard, 160 MB maximum using optional 128 MB memory module, One DIMM slot available for optional 128 MB memory module.
Media Types Supported
Plain, Recycled, Light, Heavy, Bond, Rough (no Duplex support), Coloured, Greeting Card Stock (No Duplex support), Envelopes (Supported from MPF only, no duplex support), Labels (Paper type), Transparencies (Laser), Letterhead, Preprinted.
Standard Interfaces (Cables not included)
Hi-Speed USB 2.0 port, Parallel IEEE-1284.
Languages and Fonts
3 of 9 scalable PCL 5e fonts in Narrow, Regular and Wide,2 PCL bitmap fonts,84 scalable PCL fonts,OCR-A, OCR-B scalable PCL 5e fonts,89 scalable PostScript fonts
Compatible Client Operating Systems
Microsoft® Windows® - 7 32bit/64bit,Windows® Server 2008 R2, MS Windows® 2008 Server, 2003 Server, 2000 Server, XP 32bit/64 bit, 2000, Windows® Vista® 32bit/64bit. RH Linux 3.0,4.0,5.0 WS SuSE Linux 10.x or later.NetWare 5.1, 6.0. Macintosh version (OS 9.0 or later and OS X or later,Unix( PS PPD for Sun Solaris 8,9,10.0) HP UX 11i. Citrix Metaframe. SAP.
Printer Management Software
Dell OpenManageTM (Available in Feb 2011), Lexmark MarkVisiontm/ Professional, CA's Unicenter® (non-64 bit), HP OpenViewtm/ (non-64 bit), and virtually any printer or device network management system that supports SNMP. Embedded Web Server (EWS)
