A reliable and affordable monitor with essential features that meet everyday office demands. It features great display quality at multiple angles with VESA-mount compatibility and tilt options, as well as a VGA.
Screen performance
View your applications, spreadsheets and more on Full HD clarity, with millions of colors. -
Tilt at will
Work comfortably by tilting the monitor forward or backward. -
Convenient controls
Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel.
- Dell E2216HV - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class D
- Power Consumption (On mode)
- 12.9 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.22 cm x 18 cm x 39.67 cm
- 3.35 kg
- Environmental Standards
- ENERGY STAR Qualified
- Carbon Footprint
- 440 kg carbon emissions
- RoHS, CECP
- 3-year warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- LED light bar system
- Black
- 51.22 cm x 18 cm x 39.67 cm - with stand
- 3.35 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots, arsenic free, mercury free
- Cables Included
- 1 x VGA cable
- RoHS, CECP
- Security Slot Type
- Kensington security slot
- Input Voltage
- 12.9 W
- Power Consumption SDR (On mode)
- 12.9 kWh/1000h
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 51.22 cm - depth: 18 cm - height: 39.67 cm - weight: 3.35 kg , Without stand - width: 51.22 cm - depth: 5.05 cm - height: 30.37 cm - weight: 2.83 kg
Sustainability Information
- ENERGY STAR Certified
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 86
- Manufacturing (kg CO2e)
- 301
- Logistics (kg CO2e)
- 26
- Use (kg CO2e)
- 112
- EOL (kg CO2e)
- 1
- Total Carbon w/o Use Phase (kg CO2e)
- 328
- PAIA Version
- 9/5/2018
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
