Productivity without boundaries. The 27" 4K monitor with Infinity Edge and Dell HDR. See stunning colors and exceptional details on a virtually borderless display.
See the whole picture
Discover ultimate efficiency with a 27" 4K display featuring incredibly thin bezels, ideal for a multiple monitor setup. -
Lifelike visuals
Dell High Dynamic Range (HDR) projects images with striking depth, captivating your attention and giving each job a gorgeous finish. -
Get it all done
Multitask in comfort on this device with a fully adjustable stand, Dell Display Manager and ComfortView.
- Dell E2218HN - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Energy Consumption per Year
- 23 kWh
- Power Consumption (On mode)
- 16 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (black-to-white)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 84% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 51.22 cm x 18 cm x 39.67 cm
- 3.36 kg
- Carbon Footprint
- 448 kg carbon emissions
- Plug and Play, DDC/CI, RoHS, CECP, EDID compatible, BFR-free
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 7400 2-in-1
- Display Type
- Energy Class
- Class A+
- 23 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free
- 51.22 cm x 18 cm x 39.67 cm - with stand
- 3.36 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, anti-theft protection, PVC free, Dell Soundbar mounting slots, arsenic free
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x HDMI cable
- Mounting Kit
- Optional
- Security Slot Type
- Kensington security slot
- Input Voltage
- 16 W
- Power Consumption (Typical)
- 18 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 51.22 cm - depth: 18 cm - height: 39.67 cm - weight: 3.36 kg , Without stand - width: 51.22 cm - depth: 5.05 cm - height: 30.37 cm - weight: 2.84 kg
Sustainability Information
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 86
- Manufacturing (kg CO2e)
- 303
- Logistics (kg CO2e)
- 30
- Use (kg CO2e)
- 113
- EOL (kg CO2e)
- 2
- Total Carbon w/o Use Phase (kg CO2e)
- 335
- PAIA Version
- 9/5/2018
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1
