Increase the storage capacity of your Dellâ„¢ system with this 1 TB Hard Drive from Dell. It boasts a storage capacity of 1 TB, enabling users to store large amounts of data. This hard drive features a Serial ATA and it offers a maximum rotational speed of 7,200 RPM. This product has been tested and validated on Dell systems and is compatible with select Dell Systems. It is supported by Dell Technical Support when used with a Dell system.
- Dell - hard drive - 1 TB - SATA 6Gb/s
- Hard drive - hot-swap
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Spindle Speed
- 7200 rpm
- Capacity
- 1 TB
- Form Factor
- 3.5"
- Interface
- SATA 6Gb/s
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 3.5"
