Dell 19 INCH Monitor No Stand 44.3 kWh USB 3.0 hub
Quicklinx: CS1BWS00 Mfr#: 210-AJBU
Get more productive than ever. Dell 19 monitor P1917S brings greater productivity to the workplace with added user comfort and convenience.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
  • Enhanced viewing experience
    The Dell 19 monitor P1917S is perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue.
  • Complete clarity
    Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high 4000000:1 dynamic contrast ratio.
  • Work comfortably with less stress
    Dell's ComfortView feature helps to reduce harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled.
  • Auto mode and PowerNap
    Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
  • Reliable and responsible
    Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
Dell P1917S - without stand - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class A+
Energy Consumption per Year
17 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
8 ms (grey-to-grey normal); 6 ms (grey-to-grey fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
40.56 cm x 5.03 cm x 33.43 cm
2.6 kg
Environmental Standards
ENERGY STAR Qualified
RoHS, CECP, CEL, TCO Displays
Display Type
Energy Class
Class A+
17 kWh
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.293 mm
Pixel Per Inch
86
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, ultra wide viewing angle, 84% (CIE 1976) colour gamut, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
2.6 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), anti-theft protection
Security Slot Type
Kensington security slot
14 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
ENERGY STAR Certified
10 - 80% (non-condensing)
