Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
- Dell - DDR3L - module - 16 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Dual rank, Low Voltage, registered
- Limited lifetime warranty
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Chips Organization
- X8
- Compatible Slots
- 1 x memory - DIMM 240-pin
