Dell 16GB Certified Replacement Memory Module 2133 Mhz
Quicklinx: BGPSBTBS Mfr#: A7945660
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2133MHz
Registered/Buffered: Registered
£118.27 ex VAT
£141.92 inc VAT
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Dual rank, Ultra Low Voltage, registered
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Chips Organization
X4
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2133MHz
Brand: Dell
