Whether you are presenting your ideas in a boardroom or in a classroom, the Dell 1610HD projector displays graphics and text in bright, high-contrast detail that helps you get your points across. Make effective lights-on presentations a reality with its 3500 lumens brightness and a maximum projection size of 362 inches at 10 meters (projector to screen distance) that display your ideas on a grand scale. To go a step ahead its contrast ratio of 2100:1 typical (full on/full off) and 1280 x 800 WXGA native resolution ensures you enjoy excellent visuals with rich, sharp image quality, deep colors, and easy-to-read text as well as its stunning details and depth.
With 8-watt built-in speakers, this projector will further enhance your presentations with superb audio quality. Designed to fit snugly into the palm of your hand, the infra red remote control makes it easy to perform page up and down. Packed with these and many more impressive features, this 1610HD projector delivers powerful presentation with great performance and flexibility.
- Dell 1610HD - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 2100:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 16.7 million colours
- Bulb type
- 220 Watt
- Video Input
- RGB, S-Video, composite video, component video
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 29.7 cm x 20.2 cm x 8.8 cm
- 2.4 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2100:1
- Projection Distance
- 1.2 m - 10 m
- Uniformity
- 85 %
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Bulb type
- 220 Watt
Lens
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 8 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type B (management) , 1 x serial RS-232 - 6 pin mini-DIN (PS/2 style) (management) , 1 x network - RJ-45 (management)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 29.7 cm
- 20.2 cm
- 8.8 cm
- 2.4 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
