The Touch TD1100 series of linear imaging contact readers represent the Datalogic ADC solution for customers who require a cost-effective solution for close contact bar code reading without sacrificing quality and performance.
Designed for low throughput applications within multiple markets, the Touch TD1100 readers provide the guarantee of contact reading with an excellent reading performance on virtually all linear bar codes, including damaged or poorly printed codes. Small, lightweight and low on energy consumption, the Touch TD1100 readers continue to provide robustness and a 1.5 m/5.0 feet drop resistance, which is typically included in a higher range of products.
The Touch TD1100 65/90 Pro readers provide a complete all-in-one multi-interface solution, including RS-232, USB and keyboard wedge and wand emulation, while the Touch 65/90 Lite readers provide USB or RS-232/keyboard wedge interfaces. A 'read-thru' holder provides the Touch TD1100 readers with hands-free reading capability on documents or small items.
Efficient scanning capabilities
The Datalogic Touch TD1100 can read various GS1 DataBar formats with a minimum bar width of 4 mil, enabling efficient processing of different barcode types. -
Robust environmental performance
This scanner functions effectively within a temperature range of 0°C to 50°C and operates in humidity levels from 5 to 95%, allowing it to be used in a variety of settings. -
Stable wired connectivity
Featuring wired connectivity technology, the Datalogic Touch TD1100 ensures a stable and reliable connection for seamless operation in various applications. -
Clear operational feedback
Equipped with an audible beeper and LED indicator, users receive immediate feedback, facilitating efficient workflow and ensuring successful scans.
- Datalogic Touch TD1100 65 Lite - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 15 cm
- Scan Element Type
- CCD - Red LED
- Connectivity Technology
- Wired
- 5.8 cm x 8.4 cm x 16 cm
- 130 g
- 5-year warranty
- Black
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 4 mil
- Scan Field Width
- 15 cm
- Scan Element Type
- CCD - Red LED
- Light Source Wave Length
- 640 nm
- Scan Mode
- Single-pass
- Skew (Degrees)
- 70
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 25%
- Decode Capability
- Code 93, Industrial 2 of 5, Code 39, ISBT 128, IATA, GS1 DataBar, BC 412, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, Codablock F, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, Standard 2 of 5, GS1 DataBar Stacked
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- ESD (electrostatic discharge) safe
- 1 x USB - Type A
- Included Accessories
- Holder
- Cables Included
- 1 x USB cable - 1.8 m
- RoHS, JavaPOS, IP30
- Electric Current Required
- 20 mA (standby), 100 mA (typical)
Software
- Software Included
- Drivers & Utilities, Datalogic Aladdin, OPOS/JavaPOS Drivers
- 5.8 cm
- 8.4 cm
- 16 cm
- 130 g
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
- Drop Specification
- 1.5 m to concrete
