Datalogic GD4430 Kit USB 2D Imager USB/RS-232/KBW/WE Multi-Interface
Quicklinx: CKNNWS00 Mfr#: GD4430-BKK1B
The Gryphon 4000 series represents the premium level of data collection devices from Datalogic Scanning for general purpose applications. Designed with people in mind, the Gryphon I GD4400 imager blends advanced 2D reading with motion sensing technology, producing a user-friendly device with outstanding performance.
Perfect for both handheld and presentation reading, the Gryphon I GD4400 imager features Datalogic's Motionix motion-sensing technology which detects the natural actions of the operator to automatically switch the scanner into the desired scanning mode. This technology works with or without the use of a stand, offering more operational choices. Both the aimer and sensor can be programmed to the user's desired preferences.
User comfort is maximized with the Gryphon I GD4400 imager's steady, deep red illumination light. Easier on the eyes than competitive products with flicker illumination, the highly visible 4-Dot aimer defines a precise reading zone and reduces accidental reads. The aimer's center cross provides a locator for targeted scanning in a multiple bar code environment.
The Gryphon I GD4400 2D omnidirectional reader eliminates the need for separate equipment with signature capture and document scanning capabilities. Its enhanced optics offer improved motion tolerance and high speed imaging to read fast moving codes.
  • Versatile scanning
    Equipped to handle a wide array of barcodes ranging from Australian Post to UPC-E, the Datalogic Gryphon I GD4430 barcode scanner ensures comprehensive coverage for retail and logistical applications.
  • Durable design
    With a robust drop specification of 1.8 m to concrete, this scanner is built to withstand the rigors of daily use in demanding environments, minimizing downtime due to accidents.
  • Optimal compatibility
    Designed for seamless integration with PC systems, the Datalogic Gryphon I GD4430 enhances workflow efficiency with its decoded TTL, ensuring a Plug-and-Play experience for users.
  • User-friendly notifications
    The inclusion of both LED indicator and beeper for OK notifications provides immediate, easy-to-understand feedback on scanning status, enhancing user efficiency and satisfaction.
  • Environmental resilience
    Capable of operating in temperatures as low as 0°C, the Datalogic Gryphon I GD4430 is an ideal choice for environments ranging from cold storage to outdoor retail settings.
Datalogic Gryphon I GD4430 - barcode scanner
Barcode scanner - handheld - keyboard wedge, RS-232, USB, wand - decoded
Scan Element Type
Visible laser diode
Wired
7.1 cm x 10 cm x 18.1 cm
195 g
5-year warranty
Barcode
Interface Type
Keyboard wedge, RS-232, USB, wand
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Skew (Degrees)
40
Pitch (Degrees)
40
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, British Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, MacroPDF417, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB , 1 x keyboard wedge , 1 x RS-232 , 1 x - wand
Stand
1 x USB cable
RoHS
Electric Current Required
160 mA (operating), 65 mA (standby)
7.1 cm
10 cm
18.1 cm
195 g
Limited warranty - 5 years , Limited warranty - cable - 90 days
55 °C
0 - 90%
Drop Specification
1.8 m to concrete
