Datalogic Data Logic KYMAN  802.11B/G  LASER+ GS
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 7VPJWS00 Mfr#: 944551020
The Kyman-GUN provides superior ergonomics with industrial sealing and high drop resistance for use in the most adverse conditions. State-of-the-art architecture, up-to-date communication and safety standards, as well as an integral handle make the Kyman-GUN a versatile mobile computer for scan intensive applications.
  • Rugged
    The Kyman rugged mobile computer is designed to survive demanding environments and provide ergonomics that reduce operator fatigue. A sturdy outer case with overmold protection ensures reliability and robustness. Kyman resists harsh environments, multiple drops, strong shocks, repetitive tumbles and freezing temperatures.
  • Flexible
    Kyman is available in hand-held and pistol grip models. Its detachable handle provides maximum flexibility switch between hand-held and pistol grip operations, without affecting Kyman's intrinsic robustness.
  • Versatile
    A vast variety of symbologies enable Kyman to meet every market and application objective. Kyman simultaneously supports any network option - LAN, WAN and personal area networks. GSM/GPRS/EDGE takes Kyman on the road making real-time transactions and enterprise resource access possible. Wi-Fi 802.11 b/g with Cisco Compatible Extensions (CCX) offers all the advantages of the Cisco WLAN infrastructure and the latest in security protocols, WPA and WPA2.
  • Standard
    Kyman maximizes operations for the enterprise using the fastest Intel X scale processor available.
Datalogic Kyman Gun 701-902 - data collection terminal - Win CE 5.0 - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows CE 5.0
Display
3.5" colour TFT - 320 x 240
XScale PXA270
Processor Clock Speed
520 MHz
RAM
128 MB
Supported Flash Memory Cards
miniSD
Wireless Connectivity
802.11b/g, Bluetooth
Wired Protocol
Ethernet
Barcode Reader
Yes (laser)
9.1 cm x 16.2 cm x 23.8 cm
Operating System
Display
3.5" colour TFT
Resolution
320 x 240
Colour Depth
64K colours (16-bit)
XScale PXA270
520 MHz
RAM
128 MB
ROM
128 MB - Flash
miniSD
Communications
Wired Protocol
Ethernet
Input Device
Touch-screen, keypad, navigation button
Keys Qty
53
Barcodes
Barcode Reader
Scan Element Type
Laser
Minimum Bar Width
4 mil
Expansion and Connectivity
Expansion Slots
1 x miniSD
1 x serial RS-232 , 1 x USB , 1 x LAN (supporting via optional cradle)
Lithium Ion
2200 mAh
Green Spot technology
9.1 cm
16.2 cm
23.8 cm
-20 °C
50 °C
