Datalogic Data Logic Gryphon Fixed Scanner 1D Image
Quicklinx: 85V7WS00 Mfr#: GFS4150-9
Using advanced imaging technology, the Gryphon I GFS4100 fixed mount bar code reader provides a complete self-contained solution for OEM use into self-service kiosks, price verifiers, ticket readers, document handling, and medical laboratory applications, as well as vending machines and other automated equipment.
Designed for easy integration, the Gryphon I GFS4100 reader provides a simple 'plug-and-play' solution for system designers. Constructed using high-impact resin to withstand repeated cleanings with solvents and disinfectant solutions, the sealed enclosure meets industrial standards against water and particulates to provide dependable and reliable scanning performance.
Datalogic Gryphon I GFS4100 - barcode scanner
Barcode scanner - desktop - RS-232 - decoded
Grey
Scan Element Type
CCD
Wired
5.8 cm x 5.7 cm x 3.9 cm
170 g
18 months warranty
Grey
Barcode
Interface Type
RS-232
Scan Element Type
CCD
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
GS1 DataBar
TTL Decoding
Decoded
Wired
1 x RS-232 - DB-9
RoHS, IEC 60825-1, IP54
Electric Current Required
390 mA (typical)
5.8 cm
5.7 cm
3.9 cm
170 g
Limited warranty - 18 months
50 °C
0 - 95% (non-condensing)
