The SD160 card printer features system-matched Datacard patented ribbons that activate additional features exclusive to Entrust Datacard. Upon installation, the Datacard proprietary ribbons enable all enhanced product features that help you print high-quality cards more easily. When a genuine Datacard ribbon is loaded into an SD160 card printer, the driver automatically adjusts printer settings to match the ribbon type and helps ensure excellent image quality on the cards. The printer and supplies then collectively track ribbon consumption and notify you of an upcoming ribbon replacement. Full-color ribbons provide vibrant, life-like images and detail.
- Datacard YMCKFT - colour (cyan, magenta, yellow, fluorescent, resin black) - consumables kit
- Product Type
- Consumables kit
- Printing Technology
- Dye sublimation, thermal transfer
- Printing Colour
- Colour (cyan, magenta, yellow, fluorescent, resin black)
- Yield
- Up to 300 images
- Compatible with
- Datacard SD160
Consumable
- Consumable Type
- Consumables kit
- Yield
- Up to 300 images
- Consumables Included
- 1 x ribbon (yellow/cyan/magenta/black) - up to 300 images , 1 x cleaning cards , 1 x cleaning sleeves
- Compatible with
- Datacard SD160
