D-Link Wireless N USB Nano Adapter IEEE 802.11n/11b
Quicklinx: 6KWBWS00 Mfr#: DWA-131
  • IEEE 802.11n (draft 2.0)
£9.99 ex VAT
£11.98 inc VAT
D-Link's Wireless N USB Nano Adapter delivers high performance wireless networking to a laptop or desktop PC via the ultra-fast USB 2.0. Its exceptionally small size means that you can keep it plugged in even when you're on the move.
With Wireless N technology, you get more speed, extended coverage and virtually no dead spots with the assurance that devices remain compatible with previous network standards. Securing the wireless network has never been easier, with Wi-Fi Protected Setup (WPS) which works at the touch of a button. The DWA-131 supports WEP, WPA and WPA2 encryption methods and includes a configuration utility to find available wireless networks and show quality/signal strength.
Installation is a breeze: simply insert the enclosed CD into your computer and the installation wizard - available in 18 languages! - will do the rest. No experience required.
D-Link Wireless N DWA-131 - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.8 cm x 3.4 cm x 0.8 cm
3 g
Continental Europe
802.11b/g, 802.11n (draft 2.0)
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Compatible with Windows 7
Network adapter
External
USB 2.0
Continental Europe
Wireless
Frequency Band
2.4 GHz
Status Indicators
Link/activity
WPS
Aerial
Antenna
Internal
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
WPA, WPA2
FCC Class B certified, C-Tick, IC
1.8 cm
3.4 cm
0.8 cm
3 g
10 - 90%
