The D-Link Wireless N Unified Service Router (DSR-250N) provides enhanced security, functionality and performance over a traditional VPN router without the complexity of a full firewall solution. The D-Link Wireless N Unified Service Router is a cost-effective, high performance solution for securing a small business network.
Superior wireless performance
Designed to deliver superior wireless performance, the DSR-250N include 802.11 b/g/n, allowing for operation on the 2.4 GHz wireless LAN radio bands. Multiple In Multiple Out (MIMO) technology allows the DSR-250N to provide high data rates and a wide wireless coverage area with minimized "dead spots". -
Robust VPN features
A fully featured virtual private network (VPN) provides your mobile workers and branch offices with a secure link to your network. The DSR-250N is capable of simultaneously managing 5 Secure Sockets Layer (SSL) VPN tunnels respectively, empowering your mobile users by providing remote access to a central corporate database. Site-to-site VPN tunnels use IP Security (IPSec) protocol, Point-to-Point Tunneling Protocol (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office connectivity through encrypted virtual links. The DSR-250N supports up to 25 simultaneous VPN tunnels. -
Efficient Green technology
As a concerned member of the global community, D-Link is devoted to providing eco-friendly products. D-Link green Wi-Fi and D-Link green Ethernet features save power and help cut energy usage costs. The D-Link green WLAN scheduler shuts down your wireless network automatically according to a schedule you define, allowing you to turn off your wireless network during off-peak hours, saving energy and keeping your network secure. The D-Link green Ethernet feature can detect the length of the cables connected to the router, and can adjust power usage accordingly to save energy automatically without sacrificing performance. It can also detect if a link is down on a port, and automatically puts that port into a sleep mode that drastically reduces the amount of power used. In addition, compliance with RoHS (Restriction of Hazardous Substances) and WEEE (Waste Electrical and Electronic Equipment) directives make D-Link green certified devices an environmentally responsible choice.
- D-Link Unified Services Router DSR-250N - wireless router - Wi-Fi - desktop
- Wireless router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 1 Gbps
- Performance
- Firewall throughput: 750 Mbps , VPN throughput: 95 Mbps
- Capacity
- Concurrent sessions: 20000 , VPN tunnels: 25 , SSL VPN tunnels: 5 , Firewall policies: 200 , New sessions per second: 200
- PPTP, L2TP, IPSec, PPPoE, DHCP, DNS, DDNS
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
- Firewall protection, DMZ port, DHCP support, NAT support, VPN support, PAT support, VLAN support, content filtering, IPv6 support, IPS, URL filtering, firmware upgradable, IPSec VPN, WPA2 encryption, QoS, DPD, IPSec NAT-T, WPS, DHCP server, Multiple SSID support, bandwidth control, D-Link Green Technology
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Power
- AC 100/230 V (50/60 Hz)
- 20.3 cm x 14 cm x 3.5 cm
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 1 Gbps
- Performance
- Capacity
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- DES, Triple DES, Blowfish, Twofish, MD5, AES, SSL, TLS, SHA-1, PEAP, TTLS, CAST-128, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC Class B certified, VCCI, C-Tick, cUL
- Status Indicators
- Port status, link/activity
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 8 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x console - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Directivity
- Omni-directional
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- Voltage Required
- 12.6 watt
- MTBF
- 250,000 hours
- 20.3 cm
- 14 cm
- 3.5 cm
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.03 |
