If you want to stream HD video throughout your house, then this is the adapter for you. When used with a Dual Band Router, it operates on two bands so you can avoid interference and stream away
The D-Link® Xtreme N® Dual Band USB Adapter (DWA-160) is the latest addition to the award-winning Xtreme N product family. The DWA-160 is designed for users looking to get a reliable wireless connection that can handle High-Definition (HD) video streams throughout the house. This is achieved by using the DWA-160 together with an 11n dual band router (D-Link DIR-855 or DIR-825 recommended).
BENEFITS OF DUAL BAND
The dual band N technology in the DWA-160 supports selectable 2.4GHz or 5GHz wireless signals. This allows you to check e-mail and browse the Internet using the 2.4GHz band or stream HD movies and other media on the 5GHz band. The 5GHz wireless band is the best technology available for wirelessly streaming HD videos across your network. It achieves this by operating in a clear wireless band to help avoid interference that may slow down and limit the range of current wireless technologies like 802.11g*. The DWA-160 is also backward compatible to 802.11g, which means it can be used in existing 802.11g networks.
EASY TO SET UP, EASY TO USE
The D-Link Quick Adapter Setup Wizard guides you step-by-step through the installation process. Configure this USB adapter without having to call a networking expert to help you. The DWA-160 features a Wi-Fi Protected Setup™ (WPS) Push Button for easy connection to a wireless network. The D-Link Wireless Manager is also included with this product to keep track of your most frequently accessed networks so that you can join them quickly and easily.
With unmatched wireless performance, reception, and security, the D-Link Xtreme N Dual Band USB Adapter (DWA-160) is the best choice for easily adding or upgrading wireless connectivity to your PC.
XTREME N™ DUAL BAND ADAPTER BENEFITS
-Delivers up to 14x faster speeds* and 6x farther range* than 802.11g
-Xtreme N® technology enables High-Definition (HD) video streaming, file sharing, enhanced Internet phone calling (VoIP), and Web surfing
-Access a secure wireless network using advanced WPA™ or WPA2™ encryption
-Easy to install and use with the D-Link Quick Adapter Setup Wizard or using Wi-Fi® Protected Setup (WPS) push button
-Backward compatible with 802.11g devices including game consoles and digital media players
WHAT IS DUAL BAND N?
Dual band N is the latest addition to the award-winning Xtreme N product family. The dual band technology in the DWA-160 supports 2.4GHz or 5GHz wireless signals. This allows you to check E-mail and browse the Internet using the 2.4GHz band or stream HD movies and other media on the 5GHz band. The 5GHz band helps avoid interference by providing a clearer wireless band for HD file streaming.
Maximum wireless signal rate derived from IEEE Standard 802.11g, 802.11a, and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link RELATIVE performance measurements based on the wireless range and speed rates of a standard Wireless G product from D-Link. Maximum throughput based on D-Link 802.11n devices.
Wi-Fi Protected Setup (WPS) push button available on hardware version A2.
- D-Link Xtreme N DWA-160 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 2.8 cm x 8.9 cm x 1.3 cm
- 45 g
- Data Link Protocol
- 802.11a, 802.11b/g/n
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
- System Requirements
- Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows Vista
- Microsoft Certification
- Certified for Windows Vista
- Designed For
- Amplifi DIR-857; Xtreme N DIR-825
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Status Indicators
- Link OK, link/activity
- WPS
Aerial
- Antenna
- Internal
- Directivity
- Omni-directional
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB extension cable (external)
- Encryption Algorithm
- WPA, WPA2
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- FCC Class B certified, IC
- Software Included
- Drivers & Utilities
- OS Required
- Additional Requirements
- CD-ROM
- System Requirements Details
- HD 20 MB
- 2.8 cm
- 8.9 cm
- 1.3 cm
- 45 g
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
- D-Link Amplifi DIR-857 , D-Link Xtreme N DIR-825
