D-Link Wireless-N Access Point (300Mbps)
WIRELESS N COVERAGE
Quicklinx: 72D3WS00 Mfr#: DAP-1360/B
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£21.78 ex VAT
£26.13 inc VAT
Use the Wireless N Access Point (DAP-1360) to create a new wireless network or simply extend your existing wireless network coverage to reach greater distances throughout a home or office.
Seven Operation Modes
Can be flexibly configured to operate as an Access Point, Wireless Client, Bridge, Bridge with AP, Repeater, WISP Client Router or WISP Repeater.
Total Security
Complete set of security features including WEP/ WPA/WPA2/WPS to safeguard your network against outside intruders.
Better Wireless Coverage
Wireless N draft standard offers an increased range that is six times further than 802.11g
Connect Home and SOHO To a Wireless Network
Connect this Access Point to a broadband modem and wirelessly share your Internet connection. The D-Link DAP-1360 access point is a draft 802.11n compliant device that delivers up to 14x faster speeds1 and 6x farther range1 than 802.11g while staying backward compatible with 802.11g and 802.11b devices. Enjoy surfing the web, checking e-mail, and chatting with family and friends online.
Protect Your Wireless Network and Data Easily
The DAP-1360 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. This device also supports WiFi Protected Setup (WPS) to quickly and securely setup a wireless network. In addition, it also provides MAC address filtering a nd the disable SSID Broadcast function to limit outsiders’ access to your home and office network.
Flexibly Configure Your AP for Different Applications
The DAP-1360 can be configured to operate as (1) an Access Point to act as a central hub for wireless users, (2) a Wireless Client to connect to another Access Point, (3) a Bridge to joint two wireless workgroups together, (4) a Bridge with AP to act as wireless hub and a bridge at the same time, (5) a Repeater to extend the wireless coverage to cover all "dead" spots, (6) a WISP Client Router to let wireless Internet service subscribers share Internet connection with home/office Ethernet-enabled computers without the need for an extra router, or (7) a WISP Repeater to let WISP subscribers share Internet connection with wireless computers without any extra router.
Easy to Install and Use
With D-Link Setup Wizard, you can set up your wireless network in minutes. It configures your DAP-1360’s operation mode and makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home and office.
D-Link Wireless N Access Point DAP-1360 - radio access point - Wi-Fi
Radio access point
External
Frequency Band
2.4 GHz
Vertical stand
14.8 cm x 11.3 cm x 3.15 cm
215 g
Radio access point
14.8 cm
11.3 cm
3.15 cm
215 g
External
Wireless
Line Coding Format
DBPSK, DQPSK, CCK, OFDM
Spread Spectrum Method
OFDM
Remote Management Protocol
HTTP
Frequency Band
2.4 GHz
Status Indicators
Power, LAN, wireless
Auto-negotiation, repeating mode, MAC address filtering, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), wireless bridge mode, Wireless Client Mode
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
2
Directivity
Omni-directional
Gain Level
2 dBi
1 x 100Base-TX - RJ-45
Vertical stand
1 x network cable
Mounting Kit
Included
FCC Class B certified
External power adapter
Software Included
Drivers & Utilities
55 °C
10 - 90% (non-condensing)
72D3 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
72D3 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
Resources
The following resources are available for the D-Link Wireless-N Access Point (300Mbps)
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Antennas: 2
Brand: D-Link
