D-Link Wireless N 150 ADSL Router
Quicklinx: 7CHMWS00 Mfr#: DSL-2680/UK
  • IEEE 802.11n
The Wireless N 150 ADSL2+ Modem Router is a versatile, high-performance remote router for home and the small office. With integrated ADSL2/2+, firewall protection, Quality of Service (QoS), 802.11n wireless LAN and 2 Ethernet switch ports, this router provides all the functions that a home or small office needs to establish a secure and high-speed remote link to the outside world.
The Wireless N 150 ADSL2+ Modem Router provides wireless speeds that are many times faster than 802.11g. Maximize wireless performance and stay connected from virtually anywhere at home and in the office. The DSL-2680 supports WPA/WPA2 and WEP data encryption methods for flexible user access security. The Wireless N 150 ADSL2+ Modem Router is backward compatible with existing 802.11b and 802.11g wireless equipment, ensuring compatibility with a wide range of wireless devices.
Security features prevent unauthorized access to the home and office network from wireless devices or from the Internet. The Wireless N 150 ADSL2+ Modem Router provides firewall security, such as Stateful Packet Inspection (SPI) and hacker attack logging. SPI inspects the content of incoming packets before they are allowed in, while hacker logging helps to protect your network against Denial of Service (Dos) attacks.
  • High-speed Internet
  • Ultimate wireless connection
  • Full featured security suite
  • High-speed ADSL and wireless performance
    Connect to your ADSL connection at up to 24 Mbps downstream and 1 Mbps upstream. High speed performance gives you smooth media streaming, so you can watch TV, listen to live music, broadcast over the Internet, and experience clear Internet phone calls. Wireless N 150 technology allows you to connect to 802.11n wireless devices, so you can make full use of your broadband connection.
D-Link DSL-2680 - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 2-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, DHCP
Routing Protocol
RIP-1, RIP-2, static IP routing
NAT support, Stateful Packet Inspection (SPI), packet filtering, dynamic DNS server, Intrusion Detection System (IDS), VPN passthrough, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy
IEEE 802.3u, IEEE 802.3i, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n
11.3 cm x 14.8 cm x 3.2 cm
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
150 Mbps
Routing Protocol
Status Indicators
Port status
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex L
WAN: 1 x ADSL2+ - RJ-11 , LAN: 2 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal
Antenna Qty
1
External power adapter
11.3 cm
14.8 cm
3.2 cm
5 - 95% (non-condensing)
