D-Link Wireless G Multifunction Print Server 10/100Mbps
Quicklinx: 75NHWS00 Mfr#: DPR-1040/B
The DPR-1040 Wireless G USB Multifunction Print Server is a compact and versatile print server ideal for home office, school and business use. Supporting scan, fax, and print functions, this device gives you the option of sharing one USB multifunction printer wirelessly between multiple users. This print server is based on the 802.11g wireless specification: it transfers data at speeds of up to 54 Mbps.
The DPR-1040 supports a wide range of network OS including: Windows 95/98/ME/NT 4.0/2000/XP, Apple MacOS with AppleTalk, Linux, Solaris, SCO Unix, IBM AIX and NetWare 5.x native ND S.
The Internet Printing Protocol (IPP) supported by the DRP-1040 allows remote users to output files to their home or office printer even when they are off site.
The DPR-1040 includes D-Link's Click'n Connect software (DCC). This intuitive wizard is run directly from the product CD-ROM. In a few simple steps, it takes you through setting the Print Server up and configuring the attached printers (18 languages supported).
D-Link Wireless G DPR-1040 - print server - USB 2.0 - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
5.8 cm x 9 cm x 2.7 cm
82 g
United Kingdom
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 802.11b/g
Network / Transport Protocol
TCP/IP, LPR/LPD, RAW
Frequency Band
2.4 GHz
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0
Microsoft Windows NT 4.0, UnixWare, IBM AIX, SunSoft Solaris, HP-UX, SunOS, SCO Unix, Linux, Novell NetWare 5.x, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.4.x, Microsoft Windows 2000 / ME / XP/ Vista
Print server
External
USB 2.0
United Kingdom
Ports
10/100 Ethernet
Wireless, wired
Cabling Type
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Remote Management Protocol
IPP
Frequency Band
2.4 GHz
Status Indicators
Port status, power
DHCP support, WPS
Aerial
Antenna
Internal
Antenna Qty
1
1 x 100Base-TX - RJ-45
1 x USB 2.0
1 x network cable (external)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC Class B certified, CSA, C-Tick, IC
Power adapter - external
5.8 cm
9 cm
2.7 cm
82 g
5 - 95%
