D-Link Wireless AC2600 Wave2 Dual-Band Unified Access Point
Quicklinx: F9F1WS00 Mfr#: DWL-8620AP
  • IEEE 802.11n
£192.43 ex VAT
£230.91 inc VAT
The D-Link DWL Series Unified AC Wave 2 Wireless Access Points are specially designed for small to medium businesses or enterprises, providing unparalleled bandwidth and flexibility for administrators looking to deploy a medium to large scale Wi-Fi network with manageable dual-band wireless LAN options and utilizing the cutting-edge speed of Wireless AC Wave 2. Not only can it operate in standalone mode, the D-Link Unified AC Wave 2 Wireless Access Points can also be centrally managed by D-Link Unified Wireless Controllers. Highly manageable and capable of blazing speeds, the Unified AC Wave 2 Wireless Access Points integrate seamlessly into any existing network infrastructure and can be easily scaled to meet future demands.
  • Greater speed and connectivity
    The DWL Series Unified AC Wave 2 Wireless Access Points leverage the full potential of 802.11ac Wave 2 to provide unparalleled connectivity with ultra-high combined data rates. In addition, the DWL Series supports Link Aggregation, which allows two Gigabit Ethernet ports to be linked together and act as a single port to double the available bandwidth and maximize the overall throughput of the access point.
  • MU-MIMO technology
    All models in the DWL Series support MU-MIMO (Multi-User Multiple Input Multiple Output), which enables the device to simultaneously communicate with multiple clients using multiple antennas. This allows the access point to utilize the spectrum more efficiently and significantly increase the network capacity.
  • Easy to install
    The DWL Series can be ceiling mounted or wall mounted to meet the needs of any wireless application. For additional flexibility, all D-Link Unified AC Wave 2 Wireless Access Points have integrated Power over Ethernet (PoE) support, allowing the devices to be installed in areas where power outlets are not readily available.
  • Advanced wireless features
    The D-Link Unified AC Wave 2 Wireless Access Points support 802.1p Quality of Service (QoS) for enhanced throughput and better performance of time-sensitive traffic like VoIP and streaming DSCP. All D-Link Unified AC Wave 2 Wireless Access Points support Wi-Fi Multimedia (WMM), so in the event of network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of access points are in close proximity to each other, an access point will refuse new association requests once its resources are fully utilized, allowing the association request to be picked up by a neighboring unit, distributing the load over multiple APs. Band steering technology enables Unified AC Wave 2 Wireless Access Points to intelligently place clients on the optimal wireless band to avoid congestion and allows for smooth streaming of video, seamless browsing, and fast downloads for mobile devices. Airtime Fairness ensures that equal airtime is given to each client, providing increased performance even if slower devices are connected. 802.11k Fast Roaming is also supported, which allows the wireless client to roam seamlessly between access points.
D-Link Unified AC Wave 2 DWL-8620AP - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
SSIDs total: 32 , SSIDs per radio: 16
DC 12 V
22 cm x 22 cm x 4.7 cm
790 g
Radio access point
22 cm
22 cm
4.7 cm
790 g
External
Wireless
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, SSH, CLI
Frequency Band
Power over Ethernet (PoE), VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), rogue access point detection, Link Aggregation, band steering, dual band, Fast Roaming, Airtime Fairness, 4x4 MU-MIMO technology, Station Isolation
Encryption Algorithm
AES, TKIP, WPA, WPA2
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45
MTBF
463,255 hours
BSMI, EN 61000-3-2, EN 61000-3-3, EN55024, CB, IC, UL 2043, FCC, EN 60601-1-2, NCC, RCM, EN 300 328, EN 301 489-1, EN 301 893, EN 55032, EN 301 489-17, cUL+UL
External power adapter
DC 12 V
24.24 Watt
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Protocol: IEEE 802.11a
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Brand: D-Link
