The D-Link Nuclias Connect DAP-2682 wireless access point is engineered to meet the demands of modern businesses, offering reliable connectivity and security. This device supports dual-band Wi-Fi across 2.4 GHz and 5 GHz frequencies, ensuring broad compatibility and high-speed access for all connected devices. With the inclusion of Power over Ethernet Plus (PoE+), installation and power management are greatly simplified, allowing for flexible placement and reduced cabling complexity.
Security is a priority for the DAP-2682, which comes equipped with the current WPA3 encryption, alongside support for multiple authentication methods including LDAP and RADIUS. This ensures a secure network environment, protecting sensitive data from potential threats. Additionally, the device's capacity to support up to 16 SSIDs per radio allows for efficient network segmentation, catering to diverse operational needs.
Designed for efficiency, the DAP-2682 incorporates Energy-Efficient Ethernet (EEE) and Quality of Service (QoS) features, optimizing network traffic and reducing power consumption. Its ruggedized indoor design and wall/ceiling-mountable form factor make it an ideal choice for a variety of settings, from small offices to large commercial spaces. With a mean time between failures (MTBF) of over 341,897 hours, the DAP-2682 promises reliability and longevity, making it a smart investment for any organization looking to enhance its networking infrastructure.
Multi-mode makes the most of your network capabilities
In order to achieve optimal network performance, the DAP-2682 has several operational modes tailored to fit the individual needs of your network. -
In a world where time is money, speed is essential
The DAP-2682 delivers four times the speed of wireless N by supporting concurrent dual-band performance, while an added Gigabit LAN port allows for high-capacity backhaul to the wired network. -
Take a load off and let your AP do the hard work
The DAP-2682's load balancing feature spreads the workload between two or more access points to get optimal resource utilization, throughput and response time, while airtime fairness helps distribute equal amounts of air time to each connected client. -
Peak performance and discreet deployment
The DAP-2682's PoE function allows for easy installation and a simple, clean setup. No need to run extra power lines, no added hassle when configuring your hardwiring and no more cable clutter. Perfect for advanced installations in areas where power outlets are not readily available. -
Make every second count with advanced QoS
With the use of QoS, applications such as audio, video and voice are placed in order of high-to-low priority for an all-round smoother, uninterrupted Wi-Fi experience.
 - D-Link Nuclias Connect DAP-2682 - radio access point - Wi-Fi 5
 - Radio access point
- Form Factor
 - Wall / ceiling mountable - indoor
- Data Link Protocol
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
 - 2.4 GHz, 5 GHz
- Capacity
 - SSIDs per radio: 16
- Power Over Ethernet (PoE) Supported
 - PoE+
 - 19 cm x 19 cm x 4.37 cm
 - 5.516 kg
- Ruggedized Design
 - Indoor
 - 19 cm
 - 19 cm
 - 4.37 cm
 - 5.516 kg
- Form Factor
- Connectivity Technology
 - Wireless
 - POP3, HTTP, Telnet
- Remote Management Protocol
 - Telnet, HTTP, SSH, LDAP, RADIUS
- Frequency Band
 - 2.4 GHz, 5 GHz
- Capacity
- Wi-Fi Rating
 - AC2300
- Status Indicators
 - Power, status
 - Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Access Point operational mode, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Traffic Control, rogue access point detection, Captive Portal, 802.1x authentication, band steering, guest access, Energy-Efficient Ethernet (EEE), security slot (Kensington security lock compatible)
- Encryption Algorithm
 - 128-bit WEP, 64-bit WEP, SSL, WPA2, WPA3
- Authentication Method
 - Secure Shell (SSH), RADIUS, LDAP
 - IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac Wave 2
Aerial
- Antenna
 - Internal
- Antenna Qty
 - 4
 - 2 x 1000Base-T (PoE+) - RJ-45
- MTBF
 - 341,897 hours
 - UL, FCC
 - PoE+
 - 0 °C
 - 40 °C
 - 10 - 90% (non-condensing)
