D-Link Wireless AC1750 Wave2 Dual-Band PoE Access Point
Quicklinx: F9DVWS00 Mfr#: DAP-2680
  • IEEE 802.11n
£149.57 ex VAT
£179.48 inc VAT
The DAP-2680 Wireless AC1750 Wave 2 Dual-Band PoE Access Point is designed to support small to medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the cutting-edge speed of Wireless AC.
  • Blazing wireless Wave 2 AC Performance
    The DAP-2680 delivers reliable, high-speed wireless performance using 802.11ac Wave 2 standard with maximum wireless signal rates of up to 450 Mbps over the 2.4 GHz band, and 1300 Mbps over the 5 GHz band.This, coupled with support for the Wi-Fi Multimedia (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2680 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP. The QoS feature can be adjusted through the DAP-2680 web GUI using a drop-down menu to select customized priority rules. Additionally, the DAP-2680 supports load balancing to ensure maximum performance by limiting the maximum number of users per access point.
  • Versatile access point functionality
    The DAP-2680 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. The DAP-2680 can be ceiling mounted, wall mounted, or placed on a desktop to meet any wireless demands. For advanced installations, the DAP-2680 has integrated 802.3at Power over Ethernet (PoE) support, allowing the device to be installed in areas where power outlets are not readily available.
  • Multiple operation modes
    To maximize total return on investment, the DAP-2680 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS), a WDS with Access Point, and Wireless Client. With WDS support, network administrators can set up multiple DAP-2680s throughout a facility and configure them to bridge with one another, while also providing network access to individual clients. The DAP-2680 also features advanced features such as load balancing and redundancy, for fail-safe wireless connectivity.
D-Link DAP-2680 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
19 cm x 19 cm x 4.48 cm
580 g
Radio access point
19 cm
19 cm
4.48 cm
580 g
External
Wireless
Data Transfer Rate
1750 Mbps
Remote Management Protocol
Telnet, SNMP 3, SNMP 2c, HTTP, SSH
Frequency Band
2.4 GHz, 5 GHz
Wi-Fi Rating
AC1750
Status Indicators
Power, status
LDAP support, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Network Access Protection (NAP), ceiling mountable, Energy-Efficient Ethernet (EEE)
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T (PoE+) - RJ-45
MTBF
30,000 hours
UL, FCC
PoE+
External power adapter (not included)
17.53 Watt
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1750Mbps
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Antennas: 6
Brand: D-Link
