D-Link Wireless AC1200 Wave2 Dual Band Outdoor PoE Access Point
Quicklinx: J7JLWS00 Mfr#: DAP-3666
£138.87 ex VAT
£166.64 inc VAT
The D-Link DAP-3666 wireless access point is engineered to deliver reliable, high-speed wireless connectivity in outdoor environments. Featuring a rugged design, it is built to withstand harsh weather conditions, ensuring continuous operation regardless of the elements. With dual-band Wi-Fi 5 (802.11a/b/g/n/ac Wave 2) support and 2x2 MIMO technology, it offers enhanced data rates and increased network capacity, making it ideal for supporting a multitude of devices.
Security is paramount, and the DAP-3666 excels in this aspect by offering a suite of encryption algorithms, including AES, TKIP, WEP, WPA, WPA2, and WPA2-Enterprise, to protect against unauthorized access and ensure data integrity. Additionally, it supports a variety of remote management protocols, allowing for easy and flexible network management. The inclusion of Power over Ethernet (PoE) and WMM Power Save features not only simplifies deployment but also ensures efficient power usage, making the DAP-3666 a cost-effective solution for extending wireless coverage outdoors.
  • Robust outdoor design
    Designed to withstand the elements, the DAP-3666 features a rugged outdoor chassis, ensuring durability and reliability in various weather conditions.
  • Enhanced connectivity
    With dual-band Wi-Fi 5 (802.11a/b/g/n/ac Wave 2) support and 2x2 MIMO technology, this wireless access point offers improved data rates and increased capacity, catering to all your connectivity needs.
  • Comprehensive security
    Equipped with multiple encryption algorithms including AES, TKIP, WEP, WPA, WPA2, and WPA2-Enterprise, the DAP-3666 ensures a secure wireless network environment, protecting sensitive data from potential threats.
  • Versatile management options
    Supports a wide range of remote management protocols including CLI, HTTP, SNMP, SSH, and Telnet, allowing for flexible and efficient network management.
  • Efficient power utilization
    Featuring Power over Ethernet (PoE) capability and WMM Power Save, the DAP-3666 ensures efficient power usage, reducing operational costs and simplifying deployment.
D-Link DAP-3666 - radio access point - Wi-Fi 5
Radio access point
External - outdoor
Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 1
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
Power Over Ethernet (PoE) Supported
PoE
Radio access point
Ruggedized Design
Outdoor
External
Ports Qty
2
Wireless
Network / Transport Protocol
ARP, IPv6
Routing Protocol
IGMP, STP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz, 5 GHz
SSIDs total: 16
IGMP snooping, Syslog support, MAC address filtering, Wireless Distribution System (WDS) support, SNTP support, DHCP server, Unscheduled Automatic Power Save Delivery (U-APSD), ARP spoofing, bridge mode, 2x2 MIMO technology, HotSpot 2.0, WMM Power Save
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPA2-Enterprise, WEP
IEEE 802.1D, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 1
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
Gain Level
6 dBi
1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45
IP68
PoE
Brand: D-Link
