The DIS-2650AP industrial AC1200 Wave 2 access point is designed specifically to operate in harsh environments with a wide operating temperature range and surge/ESD protection. It comes in a sturdy metal housing that can be DIN- or wall-mounted, ideal for industrial installations.
Versatile connectivity
Equipped with two Gigabit Ethernet (PoE) ports and one console port, the DIS-2650AP offers flexible connection options for a variety of networking needs, ensuring reliable and efficient communication. -
Robust security
Featuring a comprehensive suite of encryption algorithms including 128-bit WEP, 64-bit WEP, WPA, and WPA2, the DIS-2650AP provides a secure wireless network environment, safeguarding sensitive data from potential threats. -
Efficient operation
With support for ENERGY STAR and a fanless design, this wireless access point operates efficiently, reducing energy consumption while maintaining a quiet operational environment. -
Advanced wireless capabilities
Supporting IEEE 802.11ac Wave 2 along with other Wi-Fi standards, the DIS-2650AP delivers high-speed Wi-Fi connectivity across the 2.4 GHz and 5 GHz bands, accommodating a wide range of devices and ensuring optimal network performance. -
Durable and adaptable design
Designed for wall or DIN rail mounting, the DIS-2650AP is built to withstand harsh environments, with an operating temperature range from -20°C to 65°C, making it suitable for a variety of industrial applications.
 - D-Link DIS-2650AP - radio access point - Wi-Fi 5
 - Radio access point
- Form Factor
 - Wall / DIN rail mountable
- Ports Qty
 - 2
- Data Link Protocol
 - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
 - 2.4 GHz, 5 GHz
- Performance
 - Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
- Power Over Ethernet (PoE) Supported
 - PoE
- Power
 - DC 12 - 48 V
 - 19.62 cm x 10.59 cm x 4 cm
 - 785 g
 - 19.62 cm
 - 10.59 cm
 - 4 cm
 - 785 g
- Form Factor
- Ports Qty
 - 2
- Connectivity Technology
 - Wireless
 - HTTP
- Remote Management Protocol
 - HTTP
- Frequency Band
 - 2.4 GHz, 5 GHz
- Performance
- Wi-Fi Rating
 - AC1200
 - Power over Ethernet (PoE), fanless, Traffic Control, Energy-Efficient Ethernet (EEE), HotSpot 2.0
- Encryption Algorithm
 - 128-bit WEP, 64-bit WEP, WPA, WPA2
- Authentication Method
 - Radio Service Set ID (SSID)
 - IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.3at, IEEE 802.3az, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 2
Aerial
- Antenna
 - External
- Antenna Qty
 - 2
 - 2 x Ethernet 1000 (PoE) - RJ-45 , 1 x console - RJ-45
 - BSMI, FCC, RoHS, WEEE, LVD, NCC
 - PoE
- Voltage Required
 - DC 12 - 48 V
 - 14.478 Watt
 - -20 °C
 - 65 °C
 - 10 - 90% RH (non-condensing)
