The D-Link DAP-2662 wireless access point is designed to meet the needs of modern businesses and tech-savvy homes. With support for Wi-Fi 5 and dual-band connectivity, users can enjoy high-speed Internet access across both 2.4 GHz and 5 GHz bands, ensuring optimal performance for a wide range of devices. Security is a priority, with the DAP-2662 offering a comprehensive suite of encryption protocols including AES, WPA, and WPA2-Enterprise to protect your network from unauthorized access.
Power over Ethernet (PoE) technology allows for flexible installation options, reducing the need for additional power cables and simplifying the setup process. Additionally, the device's capability to support up to 16 SSIDs makes it an ideal choice for organizations requiring multiple networks. With features such as 2x2 MIMO technology and comprehensive remote management protocols, the DAP-2662 is a versatile and effective solution for enhancing your network's performance and security.
- D-Link DAP-2662 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 1
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- SSIDs total: 16
- Power Over Ethernet (PoE) Supported
- PoE
- Form Factor
- External
- Connectivity Technology
- Wireless
- ARP, IPv6
- Routing Protocol
- IGMP, STP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, SSH, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- SSIDs total: 16
- IGMP snooping, Syslog support, MAC address filtering, Wireless Distribution System (WDS) support, SNTP support, DHCP server, Unscheduled Automatic Power Save Delivery (U-APSD), ARP spoofing, bridge mode, 2x2 MIMO technology, HotSpot 2.0, WMM Power Save
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPA2-Enterprise, WEP
- IEEE 802.1D, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ac Wave 1
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T (PoE) - RJ-45
- PoE
